Author Topic: "Mile High" CB350 Four project  (Read 32537 times)
Offline calj737
  • I refuse...
Re: "Mile High" CB350 Four project
« Reply #125 on: April 23, 2017, 04:17:10 AM »
An option for "drain holes" is to dimple them outward. Promotes draining, while discouraging wicking water in. I close the front of the tray and perforate that face edge for cooling air to circulate in. Being on the face, the holes don't seem to attract any debris or moisture to speak of.
« Reply #126 on: April 23, 2017, 08:11:37 AM »
Looking great!
Offline Denver_Larry
« Reply #127 on: May 08, 2017, 04:36:44 PM »
So I'm thinking ahead and considering getting my wheels/tires ordered up and I'm wondering if anyone has tried stuffing a 120/80 tire into the back of this thing.
I've crunched all the suspension numbers and after deciding I want to target a trail number close to 97mm, picking my front tire (110/80-18), finding a shock that gets me almost 1.5 degrees less rake on the fork, a 120/80 rear will get me the rest of the way..
2005 RC51
1973 CB350F...project
« Reply #128 on: May 13, 2017, 04:52:17 PM »
Battery came in, along with my motogadget brain.  Went with a different battery so I had to mod the battery bracket a bit but I'm happy with how it came out.  I WAS going to weld studs on to secure the motogadget but I think I'll just drill the seat pan and use button head allens from underneath.  If I get them in black they will hardly be seen..
Any input regarding a 120 series rear tire on this thing?  Will it fit in the stock swingarm?
2005 RC51
« Reply #129 on: May 13, 2017, 04:57:20 PM »
Speedcell -- wow, you didn't mess around.  One of the best lithium based batteries out there - some even have a built in volt meter.  Speed Merchant uses them on their race bikes.
Online HondaMan
« Reply #130 on: May 13, 2017, 07:06:30 PM »
You may find that you have to run an extra link the the drive chain to let you move the axle back 1/2" for its 'first' slot. to move it away from the bow. I've seen them one the 350F before, though: the one I am thinking of had a 120/90-17" rear wheel, though (pseudo-chopper look).
« Reply #131 on: May 13, 2017, 11:13:18 PM »
Not too worried about the height of the tire, it's the width.   Sounds like it will fit.
2005 RC51
Offline calj737
  • I refuse...
« Reply #132 on: May 14, 2017, 03:45:15 AM »
Use stainless button heads from below, Larry. The black oxide screws will rust. You off the screws with acorns on the M-Unit.
I know you want to "center" your M-Unit, but the connector from the battery will cause some interference with the input side wires on the MU. Might need to move the MU over just a bit... OR at least, wire it all up before you mount it permanently.
« Reply #133 on: May 14, 2017, 04:00:14 AM »
Oh no black oxide!  Pro-bolt does a black finish for their stainless that will do just fine.
As for the wiring I'm reasonably confident that I can manage that with the MU centered up as I'll probably be using an M-button to bus all the input wires.
2005 RC51
Offline calj737
  • I refuse...
« Reply #134 on: May 14, 2017, 04:12:35 AM »
If you do use the M-Button, there are specific conditions to require it to function properly. Like, installed within steel bars to isolate any signal interference. I personally do NOT use it, as I have found it to be prone to issues and the convenience is outweighed by a much more simple directly wired scheme.
As a matter of fact, if you have not bought it yet, and want one, PM and address. I have several on the shelf I'll happily send along as a gift. No returns, no complaints, no finger-pointing later  ;D ;)
« Reply #135 on: May 14, 2017, 02:02:56 PM »
That would be awesome Cal, PM incoming!
2005 RC51
« Reply #136 on: June 03, 2017, 01:57:53 PM »
More progress on the frame, I think I'm finally ready to powdercoat!  I have the major electrical components all placed and secured under the seat cowl.  Last thing on the pre-PC list was getting the tank secured and I've got that sorted this afternoon.
Before the cut:
After the cut and with the mounting plate welded in:
Mounting tab made and welded to the modified original mount:
Mounted with a more modern set of hardware:
2005 RC51
« Reply #137 on: June 03, 2017, 01:58:49 PM »
And BTW, a big shout out to Cal for contributing a motogadget goodie to the project!
2005 RC51
« Reply #138 on: June 14, 2017, 08:50:04 AM »
Progress!  The powdercoater sent some pics after the frame was dipped and stripped.  A trip through the media blaster is next, hope to have it back today or tomorrow!
2005 RC51
« Reply #139 on: June 14, 2017, 12:59:09 PM »
After media blasting and a pre-bake:
2005 RC51
« Reply #140 on: June 15, 2017, 03:35:48 PM »
Got it back!  Color is a little darker than I was shooting for but I think it will be just fine.
2005 RC51
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #141 on: June 15, 2017, 03:37:46 PM »
It looks amazing. Did you fill the pits and voids in the frame Larry? If so, how? It looks like liquid, so nice.
I have a motorcycle problem.
« Reply #142 on: June 15, 2017, 04:18:07 PM »
No I didn't get to crazy with that, but they did do a very nice job anyway getting it smoothed out..
Looking forward to your latest care package so I can get the motor in there!  I think it's already shown up at home but I won't be back there for a couple days.  Assembly starts on Saturday!  ;D
2005 RC51
« Reply #143 on: June 15, 2017, 04:21:25 PM »
That is a brilliant blue. It really pops.
Offline calj737
  • I refuse...
« Reply #144 on: June 15, 2017, 04:26:03 PM »
Really striking, Larry. And if you're installing a Nils-blasted engine, holy cow!!!!
« Reply #145 on: June 15, 2017, 07:05:35 PM »
Thank guys.
Next question: what's the best way to get the original cush drives out of the rear hub?  Going to be taking it in for powder next week and I need them out..
2005 RC51
Offline NobleHops
« Reply #146 on: June 15, 2017, 08:18:58 PM »
Thank guys.
Don't do it. Leave them be. Was an enormous pain in the ass, involving torches and pointy tools. Powder with them in, it's not like they can get much harder.
« Last Edit: June 15, 2017, 08:35:54 PM by NobleHops »
« Reply #147 on: June 15, 2017, 08:35:01 PM »
Was hoping to just replace them but they don't seem to be very available.  The powder guys seemed to think they wouldn't survive all that well..
2005 RC51
Offline NobleHops
« Reply #148 on: June 15, 2017, 08:37:35 PM »
In your shoes, I'd paint that hub before doing that again.
« Reply #149 on: June 15, 2017, 08:41:30 PM »
Hmmm, there is that option.
2005 RC51
