Author Topic: "Mile High" CB350 Four project  (Read 32520 times)
Offline Denver_Larry
Re: "Mile High" CB350 Four project
« Reply #200 on: August 23, 2017, 07:15:29 PM »
Only problem I'm seeing with that is that I'll lose travel with every mm I add with the spacer... ugh
2005 RC51
1973 CB350F...project
Offline jag767
« Reply #201 on: August 23, 2017, 07:55:22 PM »
Ironically if you had gone with Hagons it'd fit fine lol.
« Reply #202 on: August 23, 2017, 08:11:52 PM »
So if I take 6mm out of the clevis, I'll still have 4mm of thickness to thread into.  Seems like that should be enough?
2005 RC51
Offline calj737
  • I refuse...
« Reply #203 on: August 23, 2017, 09:46:46 PM »
Reverse the clevis so the offset is on the chain side. That should move the spring outward.
« Reply #204 on: August 23, 2017, 10:43:09 PM »
There is no offset to the clevis from what I can tell.
2005 RC51
Offline innovativems
    • Innovative MotoSports
« Reply #205 on: August 24, 2017, 05:15:06 AM »
Had a brainstorm:  if I run the preload collars up the shocks, I could have spacers made for the bottom spring perches that would get the perch moved straight up about 15mm and I think that would do it.
Ate those race tech shocks? I wouldn't want to shim the spring up
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #206 on: August 24, 2017, 07:15:40 AM »
No, Fox.  Thought a lot about the shim last night and yeah it's a bad idea.  Most likely going to machine the clevis.
2005 RC51
« Reply #207 on: August 24, 2017, 08:45:28 AM »
I thought those looked like Fox shocks.  Are they an off the shelf model or did you have them specifically built for this bike?
« Reply #208 on: August 24, 2017, 08:54:29 AM »
Off the shelf models, I can't remember the length I used off the top of my head though.
2005 RC51
Offline calj737
  • I refuse...
« Reply #209 on: August 24, 2017, 09:21:32 AM »
Reach out to Devin. They have an offset clevis version to address this issue.
« Reply #210 on: August 24, 2017, 10:01:59 AM »
The Answer Man delivers again!
« Reply #211 on: August 24, 2017, 10:25:38 AM »
Reached out last night, waiting to hear back specifics on how it mounts and if it adds any length.  I don't want to change my geometry at this point in the game.
2005 RC51
« Reply #212 on: August 24, 2017, 12:33:17 PM »
Hopefully it just offsets the mount to provide clearance.
Offline calj737
  • I refuse...
« Reply #213 on: August 24, 2017, 12:36:05 PM »
Exactly. The clevis is offset to move shock body outboard. No change elsewhere.
« Reply #214 on: August 24, 2017, 12:36:40 PM »
That sounds like the ticket!
Offline calj737
  • I refuse...
« Reply #215 on: August 24, 2017, 12:44:18 PM »
I was at his place last year when he was dealing with the issue. IIRC the Fox shock is a few MMs wider than stock and they discovered this issue. Was when he was doing Fox 350 in fact...
« Reply #216 on: August 24, 2017, 01:34:06 PM »
This is what Devin sent for pictures.  It looks like I need a different config for the shock, and I'm not sure how the pivot mounts to the swingarm.  Really hoping it's not a welding situation...
2005 RC51
Offline calj737
  • I refuse...
« Reply #217 on: August 24, 2017, 01:53:56 PM »
Switched from clevis to eye mount. No welding only a different bolt.
« Reply #218 on: August 24, 2017, 02:11:09 PM »
Just heard back from Devin.  I was looking at the picture wrong!  It wasn't the mount that changed, it was the spring perch that changed.  He had the same idea of raising the perch, but it looks like he's done it in a way that lets the perch/spacer will overlap the shock body to a certain degree and retain the travel.
2005 RC51
« Reply #219 on: August 31, 2017, 05:00:00 PM »
Need some opinions!  Front fender arrived from Cliff and I'm debating on placement.
Slightly forward:
50/50:
Slightly back:
I've got my feelings, but I want to hear from the "mob"!
2005 RC51
« Reply #220 on: August 31, 2017, 06:56:49 PM »
50/50 looks balanced.
Offline jag767
« Reply #221 on: September 01, 2017, 02:05:15 AM »
Forward
Offline calj737
  • I refuse...
« Reply #222 on: September 01, 2017, 03:35:55 AM »
Back offers the most protection given its length. Forward balances the visual length of the bike. Middle is just that, indecisive. :)
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #223 on: September 02, 2017, 05:40:08 PM »
I like slightly back as well.  That way your painter can tell which end is which.   :)
« Reply #224 on: September 02, 2017, 05:51:32 PM »
I'll draw an arrow for you on the underside
2005 RC51
