Author Topic: "Mile High" CB350 Four project  (Read 38719 times)
Offline Denver_Larry
Re: "Mile High" CB350 Four project
« Reply #50 on: July 27, 2016, 08:05:01 PM »
Slow n' steady...
Got my valve cover back today from Nils and it of course looks great!  Did what I should have done while I was waiting for it and scrubbed up all the rockers and shafts, treated them to a light coating of oil and reassembled.  Now just need to get my intake manifold up to Hondaman so he can finish up working on my head and I can get this motor sealed back up.
2005 RC51
1973 CB350F...project
Offline knowsnothing
1978 CB750k Blue - for sale
« Reply #52 on: July 28, 2016, 02:02:03 PM »
Certainly appears to be, thanks!
2005 RC51
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #53 on: July 28, 2016, 08:38:16 PM »
No, that's the one that the starter wire and the alternator wire pass through between the starter cover and the crankcase.
I have a motorcycle problem.
« Reply #54 on: July 28, 2016, 08:44:45 PM »
Well, I need that one too...  Maybe I grab 2 and mod it for the generator cover.
2005 RC51
« Reply #55 on: August 03, 2016, 07:10:50 PM »
Got the cylinders back from the machine shop yesterday and had some time to play with things tonight.  Pistons are all in (without a ring compressor!) and it's a bit closer to being buttoned up.  Just need my head and I'm ready to get it topped off.
I am a little concerned about the tolerance of the piston skirt to the cylinder wall, it is TIGHT.  About 0.04mm.  I don't really want to start rotating the crank around until I have the head on there to keep the cylinders in place since I'm not too keen on getting the pistons back in the bores again so I guess I'll wait before giving it a few rotations.  Thoughts?
2005 RC51
Offline NobleHops
« Reply #56 on: August 03, 2016, 07:24:13 PM »
Forged pistons or cast?
« Reply #57 on: August 03, 2016, 07:49:42 PM »
Cast, Cruisin Image
I know Hondaman likes em tight, his machine shop of choice did them supposedly to his specs.
« Last Edit: August 03, 2016, 07:51:25 PM by Denver_Larry »
2005 RC51
Offline NobleHops
« Reply #58 on: August 03, 2016, 08:13:52 PM »
I think those are forged Larry. Edit, but I was wrong :-)
« Last Edit: August 03, 2016, 09:08:52 PM by NobleHops »
Offline NobleHops
« Reply #59 on: August 03, 2016, 08:21:15 PM »
Do you have a total of .004, or .004 on one side with the piston in place?
Edit: good reference thread: http://forums.sohc4.net/index.php?topic=144157.0 , deleted bad info
« Last Edit: August 03, 2016, 09:08:12 PM by NobleHops »
« Reply #60 on: August 03, 2016, 08:40:45 PM »
.04 mm measured with calipers.  Where have you seen that they are forged?  Everything I have seen has them as cast and machined, and it makes sense with the price (they are cheap).
2005 RC51
Offline NobleHops
« Reply #61 on: August 03, 2016, 09:06:01 PM »
My bad.
« Reply #62 on: August 03, 2016, 09:11:06 PM »
After reading that thread and converting my metric measurements, it sounds like I'm in the ball park.  Less worried now...
2005 RC51
« Reply #63 on: October 08, 2016, 03:25:05 PM »
Update finally!
After a busy summer, Hondaman and the machine shop finished up with my head and I was able to make some real progress with reassembly this weekend.  I was short a locating pipe between the cylinder and head so I had to wait for a small care package to arrive...
All buttoned up for now, will play with the adjusting the cam followers another day.  And one of these days I'll finish up the polish work on the clutch cover so that I can reassemble that for good.
On a side note, the CB got a new garage mate!
2005 RC51
« Reply #64 on: October 08, 2016, 03:32:21 PM »
Very nice RC51 D.Larry!  It reminds me of my dearly departed 2005.  What a machine.  Torque Beast.
« Reply #65 on: October 10, 2016, 03:03:21 PM »
Don't tell me you sent that thing to the great salvage yard in the sky?!
2005 RC51
« Reply #66 on: October 10, 2016, 04:25:45 PM »
No she has a home with a younger rider. This old man traded in for a Thruxton R.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #67 on: October 15, 2016, 07:59:47 PM »
I am also in the Denver area.  I was curious who you had do the machine work on the motor in the area?
Thanks,
Mike
« Reply #68 on: October 15, 2016, 08:41:59 PM »
Ridge Reamer did the bore, decked the head and cut the valve seats, Hondaman presided over the matter and reassembled the head for me.
2005 RC51
« Reply #69 on: October 29, 2016, 10:26:32 AM »
Anyone know of a place that does small batches of zinc plating?  I've got a handful of screws etc that need a refresh that I can't find replacements for anywhere..
2005 RC51
« Reply #70 on: October 29, 2016, 10:26:58 AM »
Or cadmium..
2005 RC51
« Reply #71 on: October 29, 2016, 10:56:39 AM »
I was recently told there is a small chromer in Yuma. Didn't think we still had one in CO.
Offline NobleHops
Re: Mile High; CB350 Four project
« Reply #72 on: October 29, 2016, 11:11:10 AM »
Larry if you strike out locally drop them in a box to me. My local guy does good work if I prep it well with the vapor blaster prior, perfectly serviceable for a SOHC. A small batch is something silly like $20, and it's a 10 minute ride to drop them off along with a prepaid box back to you, no big thing. Happy to do that for you.
N.
« Reply #73 on: October 29, 2016, 12:15:37 PM »
Thanks noble, I'll get everything together for one batch!
2005 RC51
« Reply #74 on: October 29, 2016, 02:01:26 PM »
Ok, so maybe I've gone a little too far prettying up the starter motor...
2005 RC51
