Author Topic: Gas tank winterize. no gas in tank or full tank of gas.  (Read 4016 times)
Offline mrbreeze
  • Not your average
Re: Gas tank winterize. no gas in tank or full tank of gas.
« Reply #25 on: November 03, 2006, 09:37:23 PM »
Yeah....what Bob said!
MEMBER # 257
pete75
« Reply #26 on: November 04, 2006, 02:11:26 AM »
You don't need to drain thje carbs. Just turn the tap off and run the engine until it stops.  Bikes best stored with the tank full of petrol or fully drained. Do whatever you feel happiest with - just don't leave it half full...
If mine's going to be sitting for a long period (winter qualifies :(), I drain the carbs manually. I think just running them dry leaves residual fuel in the bottoms of the bowls where it will slowly evaporate leaving residue and varnish.
I've just carbs dry  loads of times with lots of bikes, garden machinery, outboards etc over the years and never had any problems..
Offline aptech77
« Reply #27 on: November 04, 2006, 05:25:26 AM »
I guess I'm confused. Won't fuel only flow out the tube if the carb bowl is overflowing? If you are manually draining the bowls via the drain screws, nothing comes out of a tube that I know of. I just put a small tin under the carb drain as I unscrew it and then dump the drained gas into the lawnmower.
My CB400F doesn't have drain lines attached, but my CM400 and CB450SC do. I guess it depends if you have them  or not.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #28 on: November 04, 2006, 06:03:56 AM »
How do you unscrew the drain? Do you have to remove that tube first?
Offline aptech77
« Reply #29 on: November 04, 2006, 06:16:25 AM »
This is a better pic. Open this screw a turn or two...... fuel will flow out from the bowl drain/ drain line if attached.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #30 on: November 04, 2006, 06:20:01 AM »
Ah, gotcha. No such convenience on my 750. If you don't put something under the drain screw, next stop for the fuel drained is the starter cover and engine case.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #31 on: November 04, 2006, 08:55:11 AM »
Watching Speed Channel while I read this. Can tell winter is coming, the Sta-bil commercial plays every 5 minutes. Don't be" Poor Ed" in the spring! I know the text by heart.
Fonda Honda
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #32 on: November 04, 2006, 10:28:40 AM »
The 550 carbs have brass (?) screws in the bowls for drianing, but I think they drain right out the holes that the screws are in.
Gas cleans up the engine nice anyhow  ;D
Offline Klark Kent
« Reply #33 on: November 04, 2006, 12:57:46 PM »
yeah except
gas: "mmmmmm clearcoat"
B ware
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Hop on a Honda
« Reply #34 on: November 04, 2006, 02:16:36 PM »
As far as I am concerned there are too many goo's in additives to fill and store petrol per se`.
I would inhibit the fuel tank with straight diesel or home heating oil. May be dump some lube oil in there too with the petrol.
It will always keep the rust out of the container
The higher the octaine rating the more moisture loves it.
Dave
Offline cleveland
« Reply #35 on: November 05, 2006, 06:30:17 AM »
motorcycleclaude75
« Reply #36 on: November 05, 2006, 07:56:59 AM »
Hey All,
I just put my bike away yesterday.  :'(  Here is my yearly procedure:
1) Change oil and filter
2) Wash and dry completely
3) Wax everything I can get my hands on
4) Go for a quick ride  :P, fill tank and add stabilizer.  This will also get rid of any water left from washing it.
5) Oil chain
6) Spray WD-40 in muffflers and underneath fenders
7) Fog cylinders or add oil in cylinders, kick over a few times
8 ) Drain carbs via drain screws
9) remove battery and store in house. Charge it once a month
10) Cover bike with bike cover and a tarp.  I never take the cover off til spring
In my case when I drain the carbs, I shut off fuel at petcock, put a cap from a wd-40 can under each carb, loosen the drain screw and the fuel comes out the drain screw not the overflow tube.  Every bike is different.
In the spring, when I remove the cover, the bike looks like I just put it away. ;D  This has always worked for me.  Then just put in the battery, check tires etc and I'm ready for first ride.  8)
Offline Klark Kent
« Reply #37 on: November 05, 2006, 08:22:40 AM »
what kind of wax and what do you mean by 'everything'? tank, sidecovers, fenders, exhaust, engine?
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
motorcycleclaude75
« Reply #38 on: November 05, 2006, 07:23:23 PM »
Hey Klark Kent,
Yup, I wax tank, side covers, mufflers, fenders, mirrors, handlebars, frame, rims.  Basically anything that is shiny gets a coat of "Mother's" wax.
Wax leaves a thin coat of protection against the elements.  It takes some time but well worth the effort.
Claude
Offline Klark Kent
« Reply #39 on: November 05, 2006, 08:47:28 PM »
thanks for all the info claude, yer a credit to the human race
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline Pirate Gonzo
« Reply #40 on: November 06, 2006, 05:32:38 PM »
Just a thought, what if your tank is coated on the inside? I just assumed that I wouldn't have a problem with it and I really don't like storing it with that much gas since it is in my basement with the gas water heater and furnace. I do leave the float bowls full of gas. I dump Stabil in the tank and run it till I know the bowls have Stabil gas in them, then I drain the tank gas off into a gas can and use it in my snowblower over the winter.
73' CB450T
76' CB500T
76' CB550K
77' CB750K
86' 49cc Spree
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #41 on: November 06, 2006, 06:10:06 PM »
I would drain everything under those circumstances, particularly if your tank has been lined. Aside from the danger of fumes, leaving fuel in the float bowls will just lead to evaporation (the fumes you want avoid) and leaving behind varnish.
