Author Topic: Vesrah gaskets  (Read 5799 times)
Offline DaveBarbier
Re: Vesrah gaskets
« Reply #25 on: November 23, 2015, 01:59:32 AM »
What's the difference between MLS and CFM? Did you out a 650 in your 550 or is that actually a CB 650? I've been talking to calj737 about boring, porting, cam swaps etc..
+ Nothing in life worth doing is easy. CBs are very worth it!
It's still on the bench, but I'm putting a 650 motor in my 550 frame. Fun times :)
Offline AlekStooge
  • can't afford cheap stuff
Re: Vesrah gaskets
« Reply #26 on: November 23, 2015, 05:54:14 AM »
Until yesterday I thought of going the same route but I found out it is significantly heavier not just 2 lbs more then the 550, like I thought. You can't use PD46C carbs right?
Offline DaveBarbier
Re: Vesrah gaskets
« Reply #27 on: November 23, 2015, 11:25:24 AM »
Can't use the 550 carbs. That's a whole other rabbit hole. I'm using CR26's for mine.
As having lifted both engines I'll say that the 650 motor is not significantly heavier. A few pounds sounds right. I could be wrong though. You'll have to check numbers, they don't lie.
Offline AlekStooge
Re: Vesrah gaskets
« Reply #28 on: November 23, 2015, 08:24:45 PM »
MLS sounds like it's more work then I'm up for. I'd like to just put the gasket in with Hondabond, as recommended by you and cross my fingers.
Offline AlekStooge
Re: Vesrah gaskets
« Reply #29 on: December 02, 2015, 10:43:45 AM »
I think I'll call the shop and ask them to deck the head and cylinder block flat for an MLS gasket. I'm looking into getting this kit for a big bore. http://www.japbikespares.com/honda/honda-big-bore-piston-kit/honda-cb550-k-sohc-74-78-600cc-big-bore-kit-61-5mm-piston-rings-gasket
However I don't think that is an MLS gasket that come with it nor does it specify that it is a 0.038 thickness.
So trimming the dowels is a must if you go with a MLS gasket? How much more work is this?
Offline AlekStooge
Re: Vesrah gaskets
« Reply #30 on: December 02, 2015, 11:55:40 PM »
So it depends on how uneven it is in the first place because there no reason to take off a lot if it is close to flat.
Offline AlekStooge
Re: Vesrah gaskets
« Reply #31 on: December 03, 2015, 09:53:55 AM »
Yeah I told them that I'll be putting in MLS gaskets. We'll see how it turn out.
