Author Topic: Cam chain tricks?  (Read 1393 times)
Offline AlekStooge
  • can't afford cheap stuff
Cam chain tricks?
« on: November 17, 2015, 08:27:11 PM »
Anyone know any tricks to keeping the cam chain from falling in to the crankcase? I don't have an overhead hook or money to spend on a fancy setup. Any DIY tricks?
Offline goldarrow
  • one day, i'll be an
Re: Cam chain tricks?
« Reply #1 on: November 17, 2015, 08:29:55 PM »
Broom stick?
CB550 K0
Offline AlekStooge
« Reply #2 on: November 17, 2015, 08:32:53 PM »
I was looking at one in the garage I guess I could lay it on top of some bricks or firewood.
« Reply #3 on: November 17, 2015, 09:10:22 PM »
coathanger bent so it hooks where ever you want...you can drop it in there plenty, it's not going anywhere, you just have to make sure you don't kink it or jamb it when you fish it back out
Offline flatlander
« Reply #4 on: November 18, 2015, 02:07:05 AM »
a long screwdriver through the chain. or tie it up to the upper frame tube with a wire or piece of string.
Offline jonda500
« Reply #6 on: November 18, 2015, 03:46:13 AM »
exactly!  - sometimes I just let it fall in (nothing bad's gonna happen!!) and hook it out later quite easily
(there is no problem with retiming the crankshaft/camshaft - the chain plays no part in it - the mark is on the camshaft not the chain)
John
A starter clutch thread:
Offline flatlander
« Reply #7 on: November 18, 2015, 03:56:36 AM »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=8ro235m2jqpvdepbu97ks038v7&/topic,60973.0.html
« Reply #8 on: November 18, 2015, 06:09:00 AM »
 :)have just a meter of vire on it..so i can fish it up when needet
i hate all this v-w.... vords
Offline mrfish2
  • I might be a
« Reply #9 on: November 18, 2015, 06:30:15 AM »
^This!
A few zipties from the chain to the frame tube worked for me.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #10 on: November 18, 2015, 08:11:35 AM »
^This!
Yarp.
I used a bungee cord for a bit, then switched to yellow poly rope.
--Evan
1975 CB750K "Rhonda"
« Reply #11 on: November 18, 2015, 08:27:30 AM »
It won't go anywhere. You can fish it out with a expandable handle magnet.
« Reply #12 on: November 18, 2015, 08:30:30 AM »
dont make it harder than it is  :P
« Reply #13 on: November 18, 2015, 08:57:20 AM »
Right, if its a CB750, don't sweat it. Just let it fall, and fish it back with a pencil magnet when you need to. Plenty of real things to worry about.
« Reply #14 on: November 18, 2015, 09:47:07 AM »
Do you have enough to get a pencil, or piece of wire..?
Offline AlekStooge
« Reply #15 on: November 18, 2015, 11:31:02 AM »
7 birthday balloons?
That's hilarious!
I used two latters and a piece of wood.
