Author Topic: Anyone know o-ring size for the carb connecting tubes for the '75 CB400F  (Read 2335 times)
Offline trainerrob
This is the #1 o-ring in the parts fiche that is online.  I am hunting for the connecting tube o-ring size.  I believe the bike takes 12 in total, but it just feels wrong to need to order 4 entire Honda gasket kit for this.
I have found o-ring sizes to a lot of the inner carb parts, but this specific rubber is illusive.  Any wisdom is greatly appreciated.
Update:
So I have it on good authority (4into1.com) that the illusive o-ring is  sized 5.8mm × 1.9mm, which i have also found to be o-ring P006.
We can spend $11-20 per carb to order the gasket set 16010-333-315... or spend 20 cents per o-ring needed...
« Last Edit: November 19, 2015, 06:34:57 PM by trainerrob »
Offline dscri001
Re: Anyone know o-ring size for the carb connecting tubes for the '75 CB400F
« Reply #1 on: November 19, 2015, 07:39:57 PM »
I have a cb350F which I believe will have the same size. I just ordered 009 sized o-rings from amazon and got a pack of 100 for a few bucks. Cant remember the exact material type but you can find what you need there or on McMaster Carr (any fuel resistant, buna-n, viton etc). I'll have to check back on the exact measurements.
« Last Edit: November 19, 2015, 07:41:44 PM by dscri001 »
Offline Tanerrx
« Reply #2 on: November 20, 2015, 10:02:07 AM »
I'm having the same problem.  I need the o-rings that go on the brass fuel joints that connect each carburetor on my 1980 CB650.  I can't find what size they are online because they are always grouped in a gasket kit or something.
Anyone have some advice?
Offline harisuluv
« Reply #3 on: November 20, 2015, 11:10:13 AM »
2x6.
if you need some PM me and I can send you what you need for a few bucks.
Offline patanegra
I have the same issue right now and i found these http://www.theoringstore.com/index.php?main_page=product_info&products_id=2311... I am going to order them and hope for the best
