Author Topic: 1973 HONDA CB350F CARB SYNC  (Read 7587 times)
Offline jetthugo
« on: November 22, 2015, 02:39:31 PM »
Im a newbie to the whole world of bikes. I just finished doing a vacuum carb sync on my 350f. Prior to doing the carb sync it was idling at 1,200rpm, but after the sync (all for are almost tuned exact) the bike will idle at around 3,000rpm. What do I need to do to fix this? Decrease all 4 equally until they get back to 1200rpm is what I am assuming.
Re: 1973 HONDA CB350F CARB SYNC
« Reply #1 on: November 22, 2015, 04:21:51 PM »
turn the idle sync screw out to bring the idle down.
you should be doing the vacuum sync with the lowest comfortable idle for your bike.
vacuum adjustment and a blip of the throttle should be followed by adjusting the idle lower or to keep it in the 1100-1400 rpm range.
Offline jetthugo
« Reply #2 on: November 22, 2015, 05:35:37 PM »
thanks for the feedback flybox. So I adjusted the idle screws to bring down the rpm to around 1200. When I turn the throttle it hangs around 2000-3000 and takes about 30 seconds to go back to 1200. When I  rode it up and down he street, it jolts and then will kick in. So it's not riding smooth. As you mentioned earlier, since I have the rpm lowered, would I need to resync the carbs once again? Thanks for your help. Here's a video of it hanging around 2500 rpm
« Reply #3 on: November 23, 2015, 07:38:09 AM »
The hanging idle can be caused by a few things:  take your time.  eliminate each one.
vacuum leaks at the carb boots (check all 8 - probably the most common cause)
incorrect fuel level in the bowls (use the clear tube method to check http://forums.sohc4.net/index.php/topic,151263.0.html )
incorrect A/F mixture at idle (tell us what you are using for intake and exhaust, and what jet#s and mixture screw settings are)
slides sticking/not closing when throttle is released
incorrect vacuum sync
Offline jetthugo
« Reply #4 on: November 23, 2015, 08:12:41 AM »
Thanks flybox, I'll do these and get back to you to let you know what happened. I think I'll start off with readjusting the carbs once again.
« Reply #5 on: November 23, 2015, 08:18:42 AM »
if youve used any aftermarket carb rebuild parts, jets and float needles especially, tuning can be difficult.
Aftermarket float needles - often differe in length or internal spring rate.  use the clear tube method to verify float level @3-4mm below bowl gasket seam.  you can be anywhere from the (book)21mm float height up to 24mm.  bowl fuel level matters.
Aftermarket jets - can differ in length and throughput from stamped size.  use OEM Keihin for ease of tuning.
Offline harisuluv
« Reply #6 on: November 23, 2015, 08:35:26 AM »
hanging idle is usually a lean symptom.  are you running the air box or pods?  exhaust?  what mods have you got?
Offline jetthugo
« Reply #7 on: November 23, 2015, 06:17:32 PM »
The bike is all stock with no mods. The bike was running fine before I tried to sync the carbs. Almost perfectly. I screwed it up when trying to sync the carbs "perfectly" but now its all packed out. All I'm trying to do is put it back to where it was prior to trying to sync the carbs. I never took the carbs apart or anything like that because it was running fine. Definitely a beginners mistake of trying to fix something thats not broken. Learned my lesson!
Offline jonda500
« Reply #8 on: November 23, 2015, 06:56:37 PM »
You would only have to use the four sync adjusters to drop the idle speed back to 1200rpm if you can't do it using the idle speed screw - there is only ONE of these!
John
A starter clutch thread:
Offline jonda500
« Reply #9 on: November 23, 2015, 07:00:35 PM »
I am confused - which screws do you mean?
Offline jetthugo
« Reply #10 on: November 23, 2015, 07:03:49 PM »
Not in front of my bike at the moment so I grabbed this image of the Internet, but it's the one on the side that has the tip like this I hope this is the idle screw...
Offline jonda500
« Reply #11 on: November 23, 2015, 07:07:33 PM »
That is a picture of a float bowl drain screw, you have 4 of these, one on each float bowl,
John
Offline jetthugo
« Reply #12 on: November 23, 2015, 07:29:25 PM »
John
That was probably the wrong image, this is the one I was talking about. I adjusted both of these to bring the rpm down.
Offline harisuluv
« Reply #13 on: November 23, 2015, 07:47:28 PM »
Yeah man... that is the air screw.  If you were trying to vacuum sync your carbs you are way off.  Those mixture screws will only affect the rpm because you are changing the air fuel mixture.  Turn them all in til snug then turn them out 1.5 turns, then you should be roughly back to normal.
As you said, if it was running fine before, then you don't need to mess with anything else.
Offline jonda500
« Reply #14 on: November 23, 2015, 08:03:40 PM »
the inner two carbs have these idle mixture screws too, set all four to 1.5 turns out from lightly turned all the way in. Take note how many turns out the inner two are set if you haven't turned them yet so you'll know where they were set before...
John
Offline jetthugo
« Reply #15 on: November 23, 2015, 08:03:50 PM »
When I was vacuum syncing the carbs, this Emgo set was attached and I was turning these screws circled in red. After they were tuned as close as I can get them, I then played around with the air screw to bring the rpm down to about 1,200. I'll do what you said with them snug at 1.5 turns after.
Offline jetthugo
« Reply #16 on: November 23, 2015, 08:05:16 PM »
John
Damn! I didn't realize there were 4 of these. Doing all 4 would help!
Offline harisuluv
« Reply #17 on: November 23, 2015, 08:06:30 PM »
If the rpm is high after syncing the carbs, lower the idle with the "idle set screw."  As Jonda said, it's ONE big screw on the linkage.  This screw adjusts all four up or down at once.
Offline jetthugo
« Reply #18 on: November 23, 2015, 09:01:01 PM »
This one correct?
Offline harisuluv
« Reply #19 on: November 23, 2015, 09:27:27 PM »
yes
Offline jetthugo
« Reply #20 on: November 23, 2015, 09:56:20 PM »
You guys rock! I turned all 4 idle mixture screws until they were snug. Then I decreased them by 1 full turn. The bike started beautifully, but it would still hang for a bit at 2000 rpm. So I turned the idle set screw slightly and now it stays at 1200 rpm. Took it for a ride to make sure all was good and it was! I've had the bike for about 6 months now, and I knew it was not running to it's full potential. But now, it rides like it should. It purrs and rides smooth now. I appreciate everyones help and thank you all!  :D
Offline Scott S
« Reply #21 on: November 24, 2015, 04:06:05 AM »
 I'm wondering now what you used to do the sync? Did you use screws on the linkage, with the locknut, to sync them? You have to remove the tank to get to them.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline jetthugo
« Reply #22 on: November 24, 2015, 11:36:02 AM »
I took the tank off to use the EMGO carb set to sync the carbs. After that I turned the 4 idle mixture screws clockwise until they were snug (actually did not have to take the tank off for this part) then I decreased all 4 by 1 turn. Then I turned the idle set screw very slightly until the rpm was staying around 1200 rpm and not hanging. That was basically all I did.
« Last Edit: November 24, 2015, 11:37:37 AM by jetthugo »
« Reply #23 on: November 24, 2015, 11:44:08 AM »
the 4 air screws meter air into the carb throats during idle.
IN, cuts off air at idle, and makes your idle mixture RICHER
OUT increases air allowed into the carbs at idle, makes your idle mixture LEANER
for a stock bike, 7/8ths +/- turns out from seated is correct.
they should be set, and left alone unless you make changes to the intake or exhaust.
The idle set screw outside the #4 carb can be set, once your bike is at running temps, and left alone.
no need to adjust or mess with it.
your carbs have a idle cam connected to the choke lever, which should be used to control idle speed during start and warm-up.
Offline jetthugo
« Reply #24 on: November 24, 2015, 12:16:03 PM »
This is awesome information. Just to clarify, when you say IN, you mean clockwise and OUT as counter clockwise right?
