Author Topic: Non stock carb boots  (Read 1310 times)
Offline afkrejci90
« on: November 24, 2015, 11:29:24 AM »
I am ditching the standard route for more power of getting CR's and am going with a set of DCOE 40's.  I'm pretty sure the standard boots will not fit the DCOE's, so what has anyone used for carbs that are not a direct fit on the 750?  I've thought about turbo piping but not sure how flexible it will be for this application.
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline Steve_K
Re: Non stock carb boots
« Reply #1 on: November 29, 2015, 01:13:23 PM »
This is not quite the same, but I put 36mm Mikuni flat slides on my 86 750 GIXXER.  I was told that they would fit.  They did fit, but it was a major effort for them to pop on.  I don't recall the size different. but I think maybe 1 to 2 mm.  Lube carbs, heat the boots(new I hope) and some of my favorite cuss words and with the bike tied down.  I would try just one carb and one boot to see if it could be forced on.
Steve.
Steve_K
Offline Tintop
« Reply #2 on: November 29, 2015, 04:09:17 PM »
If your planning on using Webers, you need to check this thread. http://forums.sohc4.net/index.php/topic,68065.0.html
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #3 on: November 29, 2015, 04:15:06 PM »
If you are using an RC type manifold, I believe you can use stock boots. If using an MPD manifold, member 754 makes some nice straight hoses from silicone tubing. I'm using a set now, and am quite happy with them.
Offline afkrejci90
« Reply #4 on: December 01, 2015, 11:03:57 AM »
I am making my own manifold for this build. Stock boots may be an option but with some force to get them on.
'80 CB750C - Sold
'06 CBR600RR
« Reply #5 on: December 13, 2015, 08:04:12 PM »
 I dry fitted a set of webers on a 750 head once, I flipped them backwards and used 1-4, 2-3 in the opposite places. Not sure the brand of intake.
