Author Topic: Double final chain.......and a new project 750 K0  (Read 13312 times)
Offline Sgt.Pinback
Re: Double final chain.......and a new project 750 K0
« Reply #75 on: March 22, 2016, 10:05:28 AM »
Finally, weather is getting warmer so I could go on working in the garage.
Gave her new front brake lines and fluid.
Took off the rear fender, cleaned it inside and out, mounted correct rear light/turn signalbracket and put it back on the bike.
Gave her new oil. Mounted a spare ignition coil. New spark plugs. Statically adjusted the ignition.
Mounted the fuel tank from the other KO.
With the help of the BMW battery pressed the starter bottom.
Can“t believe, after 15min, putting out spark plugs for cleaning 2 times,
SHE FIRED UP
after more than 40years sitting in a shed.  One after the other cylinder came. Good girl!
3 minutes later the oil preasure signal went out.  Rev.counter spinned around but after a few minutes calmed down. Engine is rather smooth running (only 30 tkm).
Next job will be valve, chain tensioner and carb adjusting.
I am happy on this very sad day in Belgium.
« Last Edit: March 22, 2016, 10:37:09 AM by Sgt.Pinback »
Doc, I love a motorcycle!
Offline greenjeans
  • 1972 CB750K2
« Reply #76 on: March 23, 2016, 11:15:51 AM »
Great find.  It really looks to be shining up quite nicely.
Offline Sgt.Pinback
« Reply #77 on: March 24, 2016, 12:11:14 AM »
Thank you.
Offline Sgt.Pinback
« Reply #78 on: March 29, 2016, 07:34:26 AM »
Adjusted valves, ignition and carbs.
Got the electrics working, fiddled the cables through the handle bar.
Realized a "knock" in the front fork.
Had to change the front brake caliper holder, too much wear. Someone put a washer into it to fix the holder pin.
Good to have a spare holder/pin/arm.
Adjusted the front fork steering.
Wanted to do a short test around the house. No clutch.
Opened the clutch and found a homemade clutch plate.
Remembered, a clutch issue was the reason the bike was set aside in 1975 by PO.
Looking for a correct one with new springs.
« Last Edit: March 29, 2016, 07:44:06 AM by Sgt.Pinback »
Offline Sgt.Pinback
« Reply #79 on: March 30, 2016, 11:00:22 AM »
Got a used clutch plate and correct screws.
Mounted new clutch and springs.
Mounted new clutch cable. They now have a black rubber protection.
Took that old brownish rubber from the old genuine cable and fitted it to the new cable.
Took her out for a short test. Gearbox and clutch now working fine. Had to adjust the float high of carb no.3 (overflow).
Now waiting for the paint parts to finish project.
Offline Sgt.Pinback
« Reply #80 on: April 09, 2016, 07:03:07 AM »
As I will have to replace the airfilter box I decided to take out the carbs and cleaned them in my ultrasonic x-mas gift from my wife
Offline Sgt.Pinback
« Reply #81 on: April 13, 2016, 01:47:19 AM »
Got some pics from Menno.
He's  got of a lot of work with my old wrinkle tank and the body panels and
trying to cope to the paint sample (left side panel) I sended to him.
Doing an awesome work - as usual!
« Last Edit: April 13, 2016, 01:52:06 AM by Sgt.Pinback »
Offline Sgt.Pinback
« Reply #82 on: April 20, 2016, 11:41:34 AM »
Took off the alternator and gearbox cover to have them polished.
Being a family project my wife did the finish.
Offline UK Pete
« Reply #83 on: April 20, 2016, 12:33:49 PM »
Does the wife ride bikes as well uli
pete
Offline Sgt.Pinback
« Reply #84 on: April 20, 2016, 01:05:46 PM »
Last time she sat on a motorbike is 12 years ago, Lago Garda, Italy,  with a ZRX1100R.
She gave it up when we got our daughter.
Offline Sgt.Pinback
« Reply #85 on: June 13, 2016, 11:23:13 AM »
Got paint set back from Menno Dek.
Will now give her a new chain with genuine sprocket.
Offline Sgt.Pinback
« Reply #86 on: July 08, 2016, 03:34:00 AM »
Fitted genuine K0 NOS front and rear sprocket and a new chain.
Passed the MOT and made first test ride.
Will put some km on her this weekend and then adjust carbs, valves etc.
Offline hashvm
  • It's not a lesson without you making mistakes!
« Reply #87 on: July 08, 2016, 07:02:29 AM »
That thing is a beauty! good work  :)
