Author Topic: 1977 K7 neutral switch  (Read 1029 times)
Offline beemerbum
« on: November 25, 2015, 02:07:23 PM »
My neutral light recently stopped going off when bike is in gear. Where is the switch located? By any chance, does oil have to be drained to replace it if bad? If this has been covered before, I apologize in advance
Offline SKTP
Re: 1977 K7 neutral switch
« Reply #1 on: November 25, 2015, 02:26:14 PM »
I'm fairly sure oil would go everywhere if you removed it prior to draining the oil...but I but it could be done, if you did it fast and didn't mind a little mess. The switch is under the bike right beside the shifter. It also acts as the shift drum "stabilizer" and fits in a groove the width of the switch...to get it back in, you need to make sure if fits into that groove (jiggle the shift drum back and forth)...it seems difficult at first, but once you get, it...it will make sense...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: November 25, 2015, 03:15:17 PM »
In neutral, the ball on the end of the switch is at the end of it's travel and the circuit (ground) which activates the neutral light is completed. When you select a gear, the ball is depressed breaking the circuit and turning off the light. Disconnect the wire from the switch - it's held by a single screw which is easily chewed up so make sure you use a proper fitting (preferably JIS) screwdriver. If the light stays on with the wire disconnected the problem is not the switch. In this case, you need to check the wiring as it is grounding elsewhere, or as in my case a few months back, you may have a corroded section. I fixed mine by cutting out the corroded part and splicing a new length of wire in. If you do need to remove the switch you shouldn't lose too much oil - give the bike a run first to ensure most of the oil is in the tank.
You're right in thinking this has been covered before. You will find numerous threads using the search function, including how to clean and overhaul the switch. Personally I would just replace a bad switch with a new or known good one though.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline jonda500
« Reply #3 on: November 25, 2015, 03:53:19 PM »
The SSM (starter safety management) might be faulty if your bike has it?  John
A starter clutch thread:
Offline beemerbum
« Reply #4 on: November 25, 2015, 06:40:44 PM »
Thank you gentlemen. I will check out the wire first. Hopefully there lies the rub.
Offline Mantree
« Reply #5 on: November 25, 2015, 07:42:51 PM »
I have seen several of these threads lately but normally the oil switch.  It is normally a pinched wire as the switch is grounded
Sent from my SM-G900V using Tapatalk
