Author Topic: Let's Go BIG 1000cc or more  (Read 7086 times)
Offline Bill/BentON Racing
    • BentON Racing
« on: November 28, 2015, 05:45:31 PM »
This thread about going big! As it says for 1000cc builds,  parts, info, , what have you? Frank, it's for you,  time to shop!
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
Re: Let's Go BIG 1000cc or more
« Reply #1 on: November 28, 2015, 05:46:53 PM »
More,
    • BentON Racing
« Reply #2 on: November 28, 2015, 05:48:13 PM »
Yep,  ;D
Offline BPellerine
« Reply #3 on: November 28, 2015, 05:55:00 PM »
incredible bill!more than most will see in their lives!!!billp
1978 CB 750K ard and webers
another anfob
    • BentON Racing
« Reply #4 on: November 28, 2015, 06:09:14 PM »
 ;D
    • BentON Racing
« Reply #5 on: November 28, 2015, 06:10:58 PM »
 ;D
Offline BPellerine
« Reply #6 on: November 28, 2015, 06:15:43 PM »
you must have sent babyface out to look for those!billp
another anfob
Offline gschuld
« Reply #7 on: November 28, 2015, 07:53:01 PM »
Yup, that's quite a collection you have there. 8)
So perhaps I'm not understanding exactly the point of the thread, so help me out.  Are we doing a general show and tell of our big bore parts for the heck of it?  Are we looking to put together parts for Frankie's new motor project?
What's the plan here fearless leader ;D
George
Mine is bigger than yours
« Reply #8 on: November 28, 2015, 09:56:10 PM »
APE 71mm kit 1000cc with Crower rods
Thats a 67mm 890 second from right. Unknown brand BMF? on right but it's bigger  ;D get out yer calculator and convert those inches  ;) BIG!
« Last Edit: November 28, 2015, 10:20:42 PM by Jerry Rxman Griffin aka MuthaF'er »
    • BentON Racing
« Reply #9 on: November 29, 2015, 05:04:25 AM »
George,  all of that! But yes, was thinking Frank might see something,  or someone else will post about their big builds! 2016  , someone needs to go big, that's why Cobra momo going in while Stage IV head massaged, Bill
Offline gschuld
« Reply #10 on: November 29, 2015, 06:11:17 AM »
Billy,
I don't recall reading the fine details about your Cobra motor.  Since you just had her all apart, could you tell us what's inside that ancient monster?
Piston size/make/compression
Rods
Crank
Trans
Chains
Cam
Springs/retainers
Gaskets, stick with RC metal and copper o-rings?
Studs
Rotor?
Starter?
George
    • BentON Racing
« Reply #11 on: November 29, 2015, 07:58:11 AM »
George,  be glad too.
Rods RC steel, H/D bolts and bushed small ends
Crank RC lightened,  polished,  and oil holes fluted
Pistons RC 1080/ 73mm
Cylinder head RC ported and polished
Stainless valves, H/D springs and RC red aluminum retainers
Cases Main bearing studs H/D
Cases cylinder head studs H/D
RC cam chain
RC slotted cam sprocket rare, most were drilled
RC 327 cam
RC rocker box hold downs
RC 9 plate with copper metals clutch kit with H/D springs
RC sidewinder 4-1
RC lightened rotor only
Trans  undercut gears, replaced 10 gears total
Shift drum late model
Shift forks best I could fine
Kickstart only
Copper headgasket
APE manual cam chain tensioner
Elan's kit in oil pump
DynaS  and Dyna 3.0 ohm green coils
Antigravity 12 cell lithium battery
George,  that's most of it!  ;D, Bill
Offline gschuld
« Reply #12 on: November 29, 2015, 08:22:07 AM »
Nice. 8)
You are using a factory cylinder with big sleeves at 73mm?  I know the sleeves are reasonably thin at 73mm bore.  I have always wondered how well the factory cylinder supports such a large bore and thin walls since the sleeves break through the casting of the cylinder.
No problems with it so far?
Offline cbr954
« Reply #13 on: November 29, 2015, 08:51:03 AM »
I had two blocks bored for 72mm by Kenny and he used some sleeves from Dynoman as they have some that are thicker.  LA Sleeve also has some thick sleeves to use for really big stuff.  Only problems I have are I am still getting a very little oil seep after a couple of runs even with the orings around the base of the sleeves.  Still trying different things to stop the seep.   Next plan...I bought a tore down RC motor with a 73mm RC big block and other goodies :)  Should be here this week!
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
« Reply #14 on: November 29, 2015, 09:03:18 AM »
The Windows 1080 program seems to always leak a bit of oil..
« Reply #15 on: November 29, 2015, 09:34:44 AM »
You could rename this thread "big jugs and slugs".
« Reply #16 on: November 29, 2015, 10:07:13 AM »
Billet block with 72mm pistons would be nice!  No oil leaks guaranteed, right?
    • BentON Racing
« Reply #17 on: November 29, 2015, 11:09:08 AM »
Now that's funny. 72mm safer for sure.
« Reply #18 on: November 29, 2015, 02:41:42 PM »
I use 1194 around the sleeves and have had no problems with leaks. That is for tapered 915 sleeves etc too.
    • BentON Racing
« Reply #19 on: November 29, 2015, 03:16:46 PM »
Yep, what I used last time also. Works well, thanks for the tip,  Bill
Offline bear
  • Leeton in Australia
« Reply #20 on: November 29, 2015, 03:24:10 PM »
A DOHC crank crafted by Bill White in Melbourne with a set of Falicon rods.
Even I haven't been able to break Bill's gear. ;D
Brian
« Reply #21 on: November 29, 2015, 04:20:00 PM »
That AND O-rings.
Offline BPellerine
« Reply #22 on: November 29, 2015, 04:39:37 PM »
did you use that starter gear spacer Bill?billp
another anfob
    • BentON Racing
« Reply #23 on: November 29, 2015, 04:40:29 PM »
No o rings needed,Bill
No, but about to install elec start on Cobra momo!
She's ready, Cobra Girl  returns!
« Last Edit: November 29, 2015, 04:44:02 PM by Bill/BentON Racing »
Offline BPellerine
« Reply #24 on: November 29, 2015, 04:46:29 PM »
no kicking on this one !hahabillp
another anfob
