Author Topic: CB750K SOHC turn signal question  (Read 1820 times)
Offline spiritof67
« on: November 29, 2015, 11:56:23 AM »
The parts manual lists two different part numbers for the front and rear turn signals - I always thought they were four of the same. Is there a real difference, and is there a good OEM replacement for them?
Offline edwardmorris
  • Youngish
Re: CB750K SOHC turn signal question
« Reply #1 on: November 29, 2015, 12:01:34 PM »
What year? The wiring is different on the early vs late models. Yamiya has good a/m ones for the early type.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: November 29, 2015, 12:27:16 PM »
I think the housings and lenses are the same, but the front bulb socket uses the twin filament bulb (running light and turn signal), while the rear bulb socket uses a single filament bulb (turn only)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline spiritof67
« Reply #3 on: November 29, 2015, 02:57:25 PM »
...an early but not sandcast (thank God!) 1970 750...
Offline spiritof67
« Reply #4 on: November 29, 2015, 03:00:20 PM »
...and my 1975 parts manual shows for K0/K1 single wires for both front and rear.....
« Reply #5 on: November 29, 2015, 03:19:23 PM »
Yep, looks like dual filament was introduced up front in 77/78 on the 750K models. 750K models through 76' were all single element.
TAMTF...
Wilbur
Projects:
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #6 on: November 29, 2015, 04:00:08 PM »
madmtnmotors,
My 1976 K6 (owned since brand new) came with Dual Filament bulbs up front and single filament in the rear.
Charlie
Offline spiritof67
« Reply #7 on: November 29, 2015, 05:10:15 PM »
...so I'm thinking I'd better stick to single wires front and rear...but I still can't figure out why the part numbers are different.
« Reply #8 on: November 30, 2015, 03:47:10 AM »
madmtnmotors,
Charlie
Following the parts fiches, it appeared that the early models had single element front and rear, but looks can be deceiving.
I have sourced red lenses for the rear of my K8 and have considered swapping the rear to dual filament for visibilities sake...
TAMTF...
Wilbur
Projects:
Offline Patrick
« Reply #9 on: November 30, 2015, 02:46:17 PM »
I have a very early 750. It has no running lights, so single positive connection. The turn signals are only turn signals. The headlight is the running light.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #10 on: November 30, 2015, 03:00:30 PM »
 The difference may be the ground wire. I think the rears have a different ground wire. I could be wrong. I believe externally they are the same.
Offline spiritof67
« Reply #11 on: December 06, 2015, 09:09:03 PM »
Gentlemen, thank you all, and single wire OEM copies it is...
