Author Topic: Cb750 clear clutch cover  (Read 1758 times)
Offline TheCampingPost
« on: November 29, 2015, 05:56:56 PM »
So my dad brought some scrap acrylic from work and I thought it would be a good idea to make a clear clutch cover. So with a few old bits from work I started carving away. It may or may not work but hey it's fun to make. Doing some reserch This plastic melts 100 degrees hotter than the engine will get on a hot day so hopefully that won't destroy it. One worry will be the clutch actuator applying enough pressure to crack it. May be a little crappy because I'm using an old drill press and worn bits that were used on a cnc and just moving around by hand, but hell who cares if it works, it works. I'll update as I get further and this will be one of many as work out kinks. Maybe I'll sell them if they're good enough who knows.
I'm 17 and I have absolutely no clue what I'm doing.
1973 cb750  Project "Blackout"
"Do What You Can, With What You Have, Where You Are" – Teddy Roosevelt.
Current Projects
1973 cb750
1984 cb700sc
My Instagram is just small current updates made day by day
https://instagram.com/projectblackoutcb750/
Re: Cb750 clear clutch cover
« Reply #1 on: November 29, 2015, 06:15:38 PM »
Man, i will give you an A+ for effort..
 Cool idea, hope the screws dont crack it ..but they are low torque.. Using he kicker would probably break it.. Be sorta cool to see oil swirling in there..
Man would you have fun with a milling machine and rotary table..
« Reply #2 on: November 29, 2015, 08:44:33 PM »
Very cool idea.  If it works without cracking, make sure to film and post some video!
Offline CycleRanger
  • No comment about being an
« Reply #3 on: November 29, 2015, 09:23:45 PM »
Yes, cool project but acrylic probably won't be durable enough.
Lexan might work better.
« Reply #4 on: November 29, 2015, 09:27:27 PM »
I think that's what RSD uses for its Clarity line of covers.
« Reply #5 on: November 30, 2015, 06:03:36 PM »
Well my dad said they get lexan at work every once in a while so if this has problems cracking I can try lexan and hopefully it won't crack.
Current Projects
1973 cb750
1984 cb700sc
Offline CycleRanger
« Reply #6 on: November 30, 2015, 07:03:34 PM »
Is it too late to groove it for an o-ring rather than a gasket?
« Reply #7 on: November 30, 2015, 07:14:40 PM »
Great idea!
« Reply #8 on: November 30, 2015, 07:48:17 PM »
This is the first of many so I'll try that on the next one ;D
Current Projects
1973 cb750
1984 cb700sc
Offline nutrepsirthomasw
« Reply #9 on: December 03, 2015, 08:16:01 AM »
I have a laser cutter at school with the right measurements it would be a dodle to cut
Sent from my SM-T320 using Tapatalk
