Poll
It turns over i have spark on all four cylinders and bothpoints its getting fuel but it wont start. I must add i had a valve job and a 550 big bore kit done to it
Ive put in new plugs
1 (50%)
I charged the battery
1 (50%)
Total Members Voted: 2
Author Topic: I have a 1976 honda cb 550 not sure if its an f or k  (Read 898 times)
Offline Scottro 76
« on: December 01, 2015, 09:28:19 AM »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=tdsfb8553ju0dm30aqf2pbhvp3&/topic,60973.0.html
Re: I have a 1976 honda cb 550 not sure if its an f or k
« Reply #1 on: December 01, 2015, 09:56:44 AM »
thek the sentifugal regulator arm ,not are rotated 180"  ..as i renember it can be put a half rotating vrong inn..
i hate all this v-w.... vords
Offline Scottro 76
« Reply #2 on: December 01, 2015, 02:37:53 PM »
Are you saying I need to bring 1 and 4 to tdc and reset the points?
Offline calj737
  • I refuse...
« Reply #3 on: December 01, 2015, 04:15:17 PM »
That and confirm the cam is oriented properly. While cranking, what symptoms do you get?
Offline Scottro 76
« Reply #4 on: December 01, 2015, 07:58:36 PM »
Are I got it to fire after reading the manual twice. But after it ran for two or three minutes oil started running out of the filter housing
Offline calj737
  • I refuse...
« Reply #5 on: December 02, 2015, 04:37:04 AM »
Do NOT get overly zealous and torque that bolt down too tight!!!! Theres an o-ring under the cover that should be just "squishing" the case to make a seal. Way too many people crank down on that bolt and shear it, seize it, or strip the head. Technique and logic over brawn...
Offline mrbreeze
  • Not your average
« Reply #6 on: December 02, 2015, 09:52:28 PM »
Can't help but ask.......what does all this have to do with the title of the thread ???
MEMBER # 257
Offline mrbreeze
  • Not your average
« Reply #7 on: December 02, 2015, 09:53:40 PM »
Or the poll at the top of the page  ???
MEMBER # 257
« Reply #8 on: December 03, 2015, 05:09:42 AM »
Nothing, why do you ask, Fred?!
Offline mrbreeze
  • Not your average
« Reply #9 on: December 03, 2015, 11:15:31 AM »
I guess just to make sense of it. If I put up a post about tuning my bike and then start talking about masking the tank off for a paint job, people are gonna be like WTF??
MEMBER # 257
Offline goldarrow
  • one day, i'll be an
« Reply #10 on: December 03, 2015, 11:19:05 AM »
I thought I was [seeing things].....now I guess I'm not alone.
CB550 K0
Offline Scottro 76
« Reply #11 on: December 30, 2015, 04:02:51 PM »
Was away for the holiday. But anyway I've been building my bike for about a year. I stripped it down completely and powder coated the frame red. With a little gold and some black. I done a top end overhaul with a big bore kit and a Carb rebuild. But I have no top end. It runs fine from 10 to 30 MPH but that's it. I'm new to bikes and this is my first build. I need some input badly!!!
Offline mrbreeze
  • Not your average
« Reply #12 on: December 31, 2015, 12:03:10 AM »
Your subject says you have a 1976 Honda cb 550 not sure if its an f or k. The discussion is about something else. ??? ??? ??? ??? ???
MEMBER # 257
Offline flatlander
« Reply #13 on: December 31, 2015, 10:02:07 AM »
k.
