Author Topic: Another cb550f battery question  (Read 1771 times)
Offline loulou
« on: December 01, 2015, 12:52:44 PM »
Hey guys and gals
So I was driving down the motorway today and one of my side covers came flying off, yep very annoying, I'm not too sure why it wasn't pushed fully in. Anyway,  I am going to use it as good excuse to open up that back section of my bike. I have some k&n filters in place, I just ordered the m-unit, now I just need to find a decent small battery. At the moment I do not have a start switch but hopefully that will change soon, so a battery that has another juice to turn the bike on would be great. I have been looking at the shore lfx14ls-bs12 is this a good choice? Is there anything better out there?
thanks
Lewis
1976 cb550
Offline Kenzo
Re: Another cb550f battery question
« Reply #1 on: December 01, 2015, 01:24:43 PM »
Don't know if it's the best or smallest but I've had good luck with the Ballistic evo2 8 cell battery. I've run it on my dirt bike and more recently on the CB550F. With the CB stock battery bracket removed and a lithium battery you probably save ten pounds of weight.
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
Offline loulou
« Reply #2 on: December 02, 2015, 02:23:08 AM »
cheers.
hey calij737 what's a good example of a solid state combo Reg/Rec with a LiFe battery? What do most people use?
thank you
1976 cb550
Offline loulou
« Reply #3 on: December 02, 2015, 05:48:31 AM »
wow thats great. So if i purchase these two, all I have to do is build a battery box and not making any plans over the weekend and I'm sorted right? Also, I purchased the wiring kit with the m-unit, so neaten everything up.
http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=9137&utm_source=Google&utm_medium=base&utm_campaign=google-base&gclid=Cj0KEQiAyvqyBRChq_iG38PgvLgBEiQAJbasdwIsVRlevS0ZEyGuP_50TPqIY1ywsDLYM9Pd6NtXc9gaAmil8P8HAQ
and this
http://www.ebay.co.uk/itm/HONDA-CB500-CB550-CB750-Regulator-Rectifier-Ricks-Motorsport-RICKS-REG-REC-/231013215108?hash=item35c975eb84:g:MEcAAOxyrYFR22Xc
also, that eBay sale is legit right? It works out much cheaper for me to buy it from there than off the officials website.
1976 cb550
Offline loulou
« Reply #4 on: December 02, 2015, 06:11:46 AM »
I'm looking to open up that section of the bike, so I was going to place the battery (on its back), m-unit, reg/rec and start solenoid all in a tray under my new seat.
I am going to use the stock control for a little while, but maybe in the near future I will change this.
thanks for your help calj737, you have been amazing. I'm going to order those items now.
1976 cb550
Offline loulou
« Reply #5 on: December 02, 2015, 12:49:46 PM »
Hey Calj737
I have been reading that with my soon to be new set up, its important not to let the voltage of the battery go too low or too high. Some people have recommended purchasing a voltmeter for the bike so you can keep tabs on whats happening with that battery.
I am happy to install something like this on my bike, because it is small and also cheap, but what  would you do if you were out on the bike and you found the voltage to be getting too high or too low?
This is the voltmeter I'm looking at
http://www.ebay.co.uk/itm/6v-12v-24v-Programmable-LED-Battery-level-voltage-monitor-meter-indicator-J-/200843083721?hash=item2ec32e3fc9:g:dA8AAMXQVT9S2Hr5
1976 cb550
Offline loulou
« Reply #6 on: December 02, 2015, 02:09:16 PM »
You have been a great help. Thank you.
Final question (until the parts arrive and I start to panic), but can the battery, m-unit, starter solenoid and reg/rec sit in a tray/box together under the seat or do they need a little room to breath?
thanks
1976 cb550
Offline przjohn
« Reply #7 on: December 02, 2015, 03:00:09 PM »
+2 on using a Lithium and a modern rec/reg for what you want to do. The combo has worked very well for me through multiple restorations.
