Author Topic: cb 500/550 transmission counter shaft gear assembly  (Read 618 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: December 02, 2015, 11:37:59 AM »
so i have problem putting my gears back to counter shaft. so i have problem how this bush (pic1 and 2) go to counter shafts low gear?. does it go like in pic 3 or like in pic 4?
sorry bad english ;D ::)
I really appreciate if someone could reply on this.
« Last Edit: December 03, 2015, 02:08:06 AM by kranta »
Offline kranta
Re: cb 500/550 transmission counter shaft gear assembly
« Reply #1 on: December 04, 2015, 12:14:01 AM »
Up ::) :) ;D
« Reply #2 on: December 04, 2015, 04:11:40 AM »
1st gear c/s should have a dimpled bushing pressed in. The bush you show doesn't work there.
Offline kranta
« Reply #3 on: December 04, 2015, 09:19:21 AM »
That bush dimpled inside and it has oil holes. And  that bush go to 1 gear but if i but that i dont know which way that bush go to gear.
« Reply #4 on: December 04, 2015, 09:50:06 AM »
Sorry kranta, I don't have a 500 gearbox to check. If it indeed the 1st gear runs on that bush then try it in one direction and engage the sliding gear to see how far the engagement dogs enter the "slots" in the 1st gear. The shoulder on the bush may prevent full engagement....or not.
Offline Folsoe
« Reply #5 on: April 05, 2016, 01:28:11 PM »
Kranta - did you find out ? I have same issue - which Way does it sit ??
Offline Folsoe
« Reply #6 on: April 06, 2016, 02:39:12 AM »
anyone on this question pls ?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=5rvtd0r47rtjpmhqckrpgjikp1&/topic,60973.0.html
« Reply #7 on: April 06, 2016, 04:30:31 AM »
is the"re no vear marks on the kounter parts??
..often it is blanked/veared, of the moving parts,,and the diameter is kleary to be seen.as a vear marking ..make the metal brighter
.try to make a personly note to dave 500,,he is holding a rest from forum...but i have often kontakt to him use p-m.
i hate all this v-w.... vords
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #8 on: April 06, 2016, 05:18:47 AM »
Does this shed any light on your question?
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline kranta
« Reply #9 on: April 06, 2016, 11:14:49 AM »
It should go that way like in the frostboys photo.
Offline Folsoe
« Reply #10 on: April 06, 2016, 11:29:23 AM »
Thanks to you all  -    Very nice advice :).  It is now clear to me :)
