Author Topic: Minimum sleeve thickness  (Read 4288 times)
Offline dragracer
  • CB750F Dragbike
« on: December 04, 2015, 09:32:10 AM »
Quick question, can anyone tell me the minimum allowable sleeve thickness in a big bore application?? I don't want to ruin a perfectly good cylinder because its been over bored to tin foil thin sleeves. I did a quick search here but didn't find a definite answer.
Thanks in advance. I'm just exploring some potential options for a new build.
Offline cbr954
Re: Minimum sleeve thickness
« Reply #1 on: December 04, 2015, 09:39:56 AM »
Kenny at cycle x told me not to go thinner than .075"  Mine would have been .055" with a bore to 72mm so I had to go with sleeves from dynoman as his would not have been thick enough.  I wish I would have measured the thickness before I put the motors together but I didn't.
« Last Edit: December 04, 2015, 06:31:31 PM by cbr954 »
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline gschuld
« Reply #2 on: December 04, 2015, 10:09:47 AM »
I am interested in the answer to that one as well.  I don't have the answer but I will measure and report back the thickness on my RC cast block at 73mm and RC factory cylinder at 70mm for reference.  That 70mm cylinder has LOTS of sleeve thickness, far more than the 73mm naturally.
FWIW, I think Jerry has 1.2mm thickness on his sleeves bored to 73.75 pistons.
George
« Reply #3 on: December 04, 2015, 02:06:37 PM »
Correct, but I know less than you Frankie and most everyone else for that matter ;-). Mine was acquired this way and I have no background or knowledge. Sounds like a Big Jay kinda question!
Offline gschuld
« Reply #4 on: December 04, 2015, 03:28:46 PM »
The RC cast cylinder at:                     73mm is 1.57mm or .062 inches.
The RC prepped factory cylinder at: 70mm is 2.98mm or .117 inches.
Both Sleeve sets are 3.000 inches O.D.
George
« Last Edit: December 04, 2015, 04:04:54 PM by gschuld »
Offline dragracer
  • CB750F Dragbike
« Reply #5 on: December 04, 2015, 06:13:56 PM »
Thanks for that info George. And Jerry, you know a helluva lot more about these engines than I do as far as details. I know just enough to get myself into trouble, but still maintain my bike to drag race it year after year. Don't short change yourself on the knowledge you do share.
Offline dragracer
  • CB750F Dragbike
« Reply #6 on: December 04, 2015, 06:16:34 PM »
Big Jay, can you help me with an answer to this question? Or is anyone else willing to jump in with an answer.
Offline gschuld
« Reply #7 on: December 04, 2015, 06:29:43 PM »
Again, nothing definitive.  But for reference, the consensus at RC Engineering back when wheels were square, was that up to 71mm was OK for street use, anything over that they considered race only.  They never seemed to stock 72mm pistons, but they did 70, 71, and 73s, and specifically recommended using their cast block for the 73mm bore.  The description for the 73mm sleeves still reads, RC sleeves to be installed in your cylinder.  So this presumes the factory cylinder.  And RC sleeves are just a shade over 1.5mm at 73mm bore in a factory cylinder.  Take that FWIW.
Using an RC cast cylinder should give more support for thinner sleeve walls, so this makes sense.
I looked through an Action Fours and an MTC catalog, neither made specific mention of minimal sleeve thickness.
The 1976 and 1978 RC catalogs had the same material below:
Hopefully, someone with actual real world experience can shed some light on this.
George.
« Last Edit: December 04, 2015, 06:38:46 PM by gschuld »
Offline Big Jay
    • CBRzone
« Reply #8 on: December 04, 2015, 11:58:21 PM »
I have always used .080" as the desired minimum. I have gone as low as .075" a few times.
« Reply #9 on: December 05, 2015, 10:10:49 AM »
Ouch, that would make mine like a hand grenade if the measurement of 1.2mm at the bottom is accurate all the up the sleeve.
Short lived but quick ;-)
Offline cbr954
« Reply #10 on: December 05, 2015, 10:26:13 AM »
I just got a stroked motor with 73mm RC cast block, cylinder wall thickness averages .06" at the bottom of all 4 cylinders.
Offline joesmotos
« Reply #11 on: December 05, 2015, 10:36:51 AM »
I was always told .080 thou was minimum(this from my days working at Star Racing and Cope Racing)
« Reply #12 on: December 05, 2015, 11:45:30 AM »
Jery , it depends if you are racing or riding on the street a bit.
 They may be necked down slightly at the bottom , so that less meat is carved out of the cases.
« Reply #13 on: December 06, 2015, 10:58:48 AM »
Anyone ever see a sleeve that let go during runnng..? Must start leaking a lot..?
Offline BPellerine
« Reply #14 on: December 06, 2015, 02:00:07 PM »
I have a set of cyls where the sleeve pulled away from the top lip all the way around and pulled the sleeve downwards about 1/8 ins!!and that was only an 812.billp
1978 CB 750K ard and webers
another anfob
Offline bear
  • Leeton in Australia
« Reply #15 on: December 06, 2015, 02:03:43 PM »
Blowing a head gasket is usually the flag for us.
