Author Topic: One Step Forward  (Read 1151 times)
Offline Moorey
One Step Forward
« on: December 07, 2015, 08:28:08 AM »
As posted a few weeks ago I recently acquired a 76 cb750f supersport. I have just fit new coils. caps, plugs, points, condensers, stripped the carbs and ultrasonic cleaned. Rebuilt and run on a fuel bottle, now seems to run sweet just needs a chance to get it on the road to test. So today I thought I would clean out the tank as there was a bit of crap and rust in it. Put a few nuts and bolts in it and gave it a good shake. Drained it and flushed it out with clean fuel. Put it back on the bike and filled with fuel only to find out it now has a pin prick hole in it. So the tank is back off and drained the hole cleaned up and I will solder it up  sometime shortly.
Question   When it is soldered  should I use something like POR15 tank sealer or wait and see if anymore holes develop.
Cheers Chris.
Offline calj737
  • I refuse...
Re: One Step Forward
« Reply #1 on: December 07, 2015, 08:29:52 AM »
Tank liners are either a "preference" or "required" due to pinholes. If you are not opposed to a liner (I'm not)  then line it and move along and forget the soldering.
Offline Powderman
« Reply #2 on: December 07, 2015, 08:46:22 AM »
If you're having to fix pin holes now, more will follow. It would be smart to seal it at this point.
« Reply #3 on: December 07, 2015, 08:55:56 AM »
I soldered my tank and I happy with it.
Prefer that to a liner.
Offline Moorey
« Reply #4 on: December 07, 2015, 09:51:04 AM »
Its just that soldering is quick and easy.
Offline BollarNPS
« Reply #5 on: December 07, 2015, 05:22:32 PM »
I chose to have a radiator company redkote mine and it is working great so far.
Offline jonda500
« Reply #6 on: December 07, 2015, 06:19:25 PM »
I braized all of the many pin holes in my 500 tank and had it professionally resprayed nearly three years ago - it still is leak free and has NO tank liner as I hate those fickle freakin things!
John
A starter clutch thread:
Offline Trad
« Reply #7 on: December 07, 2015, 08:55:24 PM »
The only problem is that if you have one or a few pinholes spring up, you can bet it's almost as thin in many other areas of the tank. Just saying that's usually the case.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Moorey
« Reply #8 on: December 08, 2015, 02:03:22 AM »
Soldered the tank this morning and took the bike for a run 50mls it now runs great at any speed throughout the rev range, smooth as silk, well happy. ;D ;D ;D
