Author Topic: '77 CB550F Brakes Too Tight, Too Squishy  (Read 627 times)
Offline meltshow
  • Don't have a cow, man.
« on: December 08, 2015, 09:21:39 PM »
Ah yes, brakes. I've having trouble with the front brake caliper fitting far too snugly to the rotor. I've replaced the piston in the caliper (was pitted) and the rubber ring. I used a wire wheel to clean out the piston (and that groove the rubber ring fits into). It's clean as a whistle. When I reassembled the front caliper after replacing piston, rubber ring and brake hoses, and ran new brake fluid through the master cylinder, the outside brake pad basically traveled all the way until it was clamping down on the rotor. Meanwhile, the brake lever is really squishy, even after bleeding the brake lines. I'm actually back where I was when I brought the bike home: brake pads are too tight, brake lever is squishy/soft. Is the next thing for me to look at the master cylinder?
Max
'82 Vespa P80X
'79 Vespa P200E
'77 Honda CB550F
'64 Honda CT200
Offline meltshow
Re: '77 CB550F Brakes Too Tight, Too Squishy
« Reply #1 on: December 09, 2015, 07:48:26 AM »
Thank you so much for the tip. The first time I bled the brakes, I did see bubbles coming up inside the MC. When you say report unit, do you mean the whole assembly? I'd assume that this is what folks go for: http://www.davidsilverspares.com/CB550F-SUPER-SPORT-1977-USA/part_123898/ over at DavidSilverSpares.com.
Max
'82 Vespa P80X
'79 Vespa P200E
'77 Honda CB550F
'64 Honda CT200
Offline CBGhia
« Reply #2 on: December 09, 2015, 08:32:59 AM »
You might just try cleaning out the master cylinder with a little bit of wire.  Poke the wire into the holes inside of there and see if that helps things.
Also, have you replaced the brake lines?  They can collapse inside and cause issues like this too.
Offline meltshow
« Reply #3 on: December 09, 2015, 08:46:10 AM »
The brake lines are brand new. Would I need to disassemble the master cylinder to clean out those holes?
Max
'82 Vespa P80X
'79 Vespa P200E
'77 Honda CB550F
'64 Honda CT200
Offline CBGhia
« Reply #4 on: December 09, 2015, 12:16:36 PM »
Probably not.  Just fish some slim wire, like thin bailing wire, in there. guitar string would work, too.
Offline jonda500
« Reply #5 on: December 09, 2015, 03:23:03 PM »
I used a single wire brush bristle held in a pair of pliers...
John
A starter clutch thread:
Offline przjohn
« Reply #6 on: December 09, 2015, 04:41:07 PM »
Did you install new pads with the new piston? Is the caliper piston retracted all the way in the caliper housing?
