Author Topic: Powdercoating flanges  (Read 5309 times)
Offline thelowmax
« on: December 11, 2015, 11:23:43 AM »
Anybody ever powder coat exhaust flanges?
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline Powderman
Re: Powdercoating flanges
« Reply #1 on: December 11, 2015, 12:26:41 PM »
What are your concerns? What color do you want them?
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: December 11, 2015, 02:04:42 PM »
Can powercoat withstand direct exhaust temps? Personally, I'd go with ceramic coating.
Offline Patrick
« Reply #3 on: December 11, 2015, 02:23:02 PM »
Since powdercoat is melted on at a much lower temp than an exhaust produces (350-400 degrees F), I think it unlikely it could take the heat without melting every time you run the bike.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Tim2005
« Reply #4 on: December 11, 2015, 02:52:08 PM »
I've had them done & it worked fine- didn't melt at all. Surprised me a bit tbh.
Offline Powderman
« Reply #5 on: December 11, 2015, 09:11:51 PM »
Where did you get that info from ? Powder is cured at 400*f and once cured can withstand spikes of 100* over cure temp (500*). I'm pretty sure that on an IL Honda the collars don't exceed 500*during normal use. If you want them black ceramic coating would be a wise choice for piece of mind.
Now I have measured H-D V-Twins that easily exceed 750* at the exhaust port, most V-Twins seem to run higher exhaust temps than a multi cylinder JDM bike.
« Last Edit: December 11, 2015, 09:13:42 PM by Powderman »
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: December 12, 2015, 05:47:27 AM »
Any coatings that resemble chrome ?
Offline thelowmax
« Reply #7 on: December 12, 2015, 12:35:25 PM »
Or clear?
Offline Dimitri13
  • 1974 CB550K
« Reply #8 on: December 12, 2015, 01:44:53 PM »
I had my engine covers done in powdercoat "chrome." Just a silver base with glossy topcoat. Not sure about other options though.
Offline RSchaefer
« Reply #9 on: December 12, 2015, 03:31:24 PM »
Did you do the valve cover as well?  Any issues if so?
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Rookster
« Reply #10 on: December 12, 2015, 04:13:29 PM »
I did my flanges in duplicolor clear engine enamel.  They turned a nice shade of dark purple and bronze.  However hot they get it was too much for the duplicolor.  You can see the bronze color on the spigot.
Scott
Offline Dimitri13
  • 1974 CB550K
« Reply #11 on: December 12, 2015, 05:00:01 PM »
I did the valve cover in a different color. I haven't run the engine yet, so I can't say for certain. But there shouldn't be any issues if the powder was done properly.
Offline RSchaefer
« Reply #12 on: December 12, 2015, 06:11:04 PM »
I did all of my covers in clear powder and the valve covers are starting to show spider veins throughout, must be the large areas of clear powder?
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Powderman
« Reply #13 on: December 12, 2015, 07:39:39 PM »
Powder doesn't know how large of an area it is on. Spider cracking is usually an indication of under cure.
« Reply #14 on: December 13, 2015, 12:25:47 AM »
Ceramic powdercoating in chrome.
Offline Powderman
« Reply #15 on: December 13, 2015, 08:43:29 AM »
Short answer is NO, there are no powders that resemble chrome in the least.
While chrome powders look pretty reflective on it's own it must be clear coated to avoid oxidation of the surface. When clearing it, it will lose about 20% of it's POP and shine.
Ceramic coating is in no way related to powder coating, one is powder, the other is a liquid spray on product. Cermachrome is a chrome ceramic that after curing needs to be either hand polished with steel wool or run through an expensive tumbler filled will expensive media. On these exhaust collars I don't see either method working as the media is too large to get in between the fins.
« Reply #16 on: December 13, 2015, 08:48:20 AM »
 Jet Hot wouldn't work on those?? I have used them for several exhaust systems and the get all round the flange area etc.
Offline Powderman
« Reply #17 on: December 13, 2015, 08:52:41 AM »
This didn't make sense. can you correct it so it does?
« Reply #18 on: December 15, 2015, 03:21:35 PM »
 I haven't tried the polished silver on 750 or 550 exhaust flanges but Hindle exhaust systems ( I have coated 3 of them) use a separate spigot that bolts to the head. They have many nooks etc and they polished up fine from Jet Hot.
 I saw "resembles chrome" but is a spray powder type of coating. I don't how close they want it to be especially with that crap the Japanese called chrome from the 70"s. I hope that makes sense.
 With a name like "powderman" I have to guess you are in the business and know everything about it.
Offline Powderman
« Reply #19 on: December 15, 2015, 03:37:08 PM »
You would be correct on my profession.
Your post said " Jet Hot wouldn't work on those?? I have used them for several exhaust systems and the get all round the flange area etc."
I assume you meant "THEY get all round the flange area" If so, your post makes no sense. The first sentence says it won't work. The second sentence implies that they did a complete job.
« Reply #20 on: December 15, 2015, 03:54:58 PM »
I'll work on my syntax. ;D
Offline Powderman
« Reply #21 on: December 15, 2015, 05:18:38 PM »
How about starting right now? Does Jet Hot work or doesn't it?
« Reply #22 on: December 18, 2015, 04:44:24 AM »
No....the first sentence is not a statement saying it doesn't work. If it was there would be a period at the end of the sentence
  The question marks imply disbelieve on my part that the Jet Hot coating would not be effective. I believe it is a viable choice as it has worked on the exhaust spigot pieces found on the Hindle systems.
  Punctuation has a significant impact (as it should) on how written material is inferred.
« Last Edit: December 18, 2015, 05:02:19 AM by MRieck »
Offline Powderman
« Reply #23 on: December 18, 2015, 09:21:31 AM »
On the spigots I can see it working. I just don't see the tumbler media getting into all the areas between the fins on the collars. I could be wrong. I did overlook the ? in the first sentence, my apologies.
Offline calj737
  • I refuse...
« Reply #24 on: December 18, 2015, 11:19:12 AM »
So is this a thread about exhaust flanges or a grammar lesson? Didn't realize that professional powder coaters also had advanced degrees in literature. This forum is an amazing source of undocumented secrets and knowledge.
Did I spell that right?
