Author Topic: dual disc conversion for 750 link no good?  (Read 2619 times)
DH
« on: December 12, 2015, 04:46:07 PM »
Anyone know where the conversion thread for twin front disc went? The links for the 750 and 500/550 don't work any more.
thx..
Offline WV_750
Re: dual disc conversion for 750 link no good?
« Reply #1 on: December 12, 2015, 05:57:33 PM »
There are a few different posts that talk about dual disc conversions. I've had better luck searching the site with google rather than the site's own search function. You can limit google's search to just these forums by following your search terms with site:forums.sohc4.net
Here's a link to save you a little time for this search: https://www.google.com/?gws_rd=ssl#q=dual+disc+site:forums.sohc4.net
73 CB750 K3
76 CT90
78 CT90
07 CB900F (919 Hornet)
DH
« Reply #2 on: December 12, 2015, 08:55:46 PM »
Should've thought of google first :P.     Here it is................. And thanks for the tip, got me on track.
https://s3.amazonaws.com/sohc4-articles/CB750K/dualdiskconversion-cb750.pdf
EDIT  The article on SALOCAL is the same as above.
« Last Edit: December 12, 2015, 09:10:36 PM by DH »
Offline Mr Freeze
« Reply #3 on: December 12, 2015, 09:04:55 PM »
This is the easiest thing and I don't know why no ever brings it up. Get a front end from a 77 or 78 Supersport. Easiest swap there is. No alignment to do and those calipers stop better than the floating ones.
« Last Edit: December 12, 2015, 09:11:17 PM by Mr Freeze »
Offline mrfish2
  • I might be a
« Reply #4 on: December 12, 2015, 09:22:11 PM »
Because a complete front end from those years is a lot harder to find than an extra caliper arm, caliper, and rotor from almost all the years.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
DH
« Reply #5 on: December 12, 2015, 09:22:34 PM »
Yup, and I''d go that route if not for the fact that I'm trying to up grade and retain stock appearance. Thanks for that note. On a related note..
Does anyone have a good way to get the "reverse flair" fitting out of an earlier 750 caliper? If I'm right, this fitting needs to be pulled out and re installed in the hole where the bleeder USED to be in the REPLACEMENT caliper for the RIGHT side.
So far, I have been unsuccessful using a cut off finish nail.
Offline DaveBarbier
« Reply #6 on: December 13, 2015, 05:19:09 AM »
I used a screw. http://forums.sohc4.net/index.php/topic,140833.msg1699993.html#msg1699993
But this might make them unusable. I'm not sure if you can get these things still. I would probably try PB blaster and propane or MAPP gas and then the nail approach again.
DH
« Reply #7 on: December 13, 2015, 05:49:24 PM »
Thanks for the caliper shots dave. I wasn't sure what the whole thing looked like. I'm going to try salvage another one from a junk
caliper I have, in case I mess up and destroy the current one.
« Reply #8 on: December 14, 2015, 04:08:17 AM »
What about the cover?
Is there a cover for the right rotor?
Or possible to modify the OEM, left cover? Better if there are dual covers available that look similar and fit.
It will look better with cover for each rotor. My bike need better brakes with OEM look.
DH
« Reply #9 on: December 14, 2015, 05:59:07 AM »
I agree.  I wish there was a shield/guard available. Nobody makes one for the right side as far as I know. Not sure how to modify
a left one to work.
« Reply #10 on: December 14, 2015, 07:09:49 AM »
Check out the links below  ;)
Branden,
I had a choice to either modify the speedo drive plate to fit the rotor center, or, modify the rotor carriage to fit the speedo drive plate.  Both are shown in this post.  I chose to modify the speedo drive plate as the wheel I bought off a forum member came with one attached  ;D  The mod took maybe an hour with a dremel and hand files.  A sloppy fit here is desireable so the drive plate doesnt bind.
I must have read these two posts 10 times while sourcing parts to be sure I got all I needed and had the mod process in my  mind.
http://forums.sohc4.net/index.php?topic=53532.0
http://forums.sohc4.net/index.php?topic=38242.msg493516#msg493516
Godffery offers the rotor carriage mod if you get your rotors through him.
Shawn @ Slingshot Cycles made my lines.  Ordered Wednesday. Came Monday.
Right under my lower triple there is a clip where the brake lines sit.
i'll run both through there to keep them up and off the tire.
i'm running 2 lines up to the MC.  not a splitter like other bikes.
« Reply #11 on: December 14, 2015, 09:38:51 AM »
None available for the right side.  I bet someone with a 3d printer and time on their hands could make one!
Wobbly
« Reply #12 on: December 14, 2015, 10:23:14 AM »
It's pretty tight as is without the cover--never mind two of them.
« Reply #13 on: December 14, 2015, 12:48:59 PM »
Tom, your dual brakes look really beautiful! The rotors fits very well, like designed for the bike.
I'll try without cover.
