Author Topic: K0 front brake disc identification  (Read 754 times)
Swoop
« on: December 15, 2015, 01:27:56 PM »
Howdy,
Do any of you K0K0 nuts out there have any idea how to tell the difference between a K0 disc and a later disc?
I have a number of them and that all have different numbers and stampings on the outside inner face.
Thanks in advance.
Steve
Re: K0 front brake disc identification
« Reply #1 on: December 15, 2015, 05:30:30 PM »
The aluminum centre piece..look at the outer edge..does it taper off to a point, or is it a square edge ?
 If the periphery is square..its KO..
Offline Patrick
« Reply #2 on: December 15, 2015, 07:22:34 PM »
The K0 disk is also smaller in circumference to the later disks.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline kmb69
« Reply #3 on: December 15, 2015, 08:58:21 PM »
Pretty sure they are the same diameter. Will double check tomorrow and report back if I'm wrong.
« Reply #4 on: December 15, 2015, 09:03:18 PM »
I thought they were the same, too. In any case, here is a pic of the most visible feature that Frank mentioned:
Offline CycleRanger
  • No comment about being an
« Reply #5 on: December 15, 2015, 09:09:36 PM »
Here's another shot of a K0 rotor.
Swoop
« Reply #6 on: December 16, 2015, 09:36:57 AM »
Thanks Frank...and the rest of you
I have it figured out now. Seems that I have one...but may need a bit of resurfacing.
I have heard that it is not easy to do. What kind of equipment would be used to resurface? Is it even doable?
Thanks
Steve
« Reply #7 on: December 16, 2015, 04:20:42 PM »
Blocksanding on a lathe can do wonders..surprising difference.
But if borrowing a lathe make sure its okay..i very rarely sand on my lathe, and cover it all up if I must.
 A lot of the grind resurfacers out there get a finish that never came out of Japan.
 I was trying to set up to do a factory type regrind..but its on hold right now..
