Author Topic: Cobra motor disassembly and rebuild  (Read 107714 times)
Re: Cobra motor disassembly and rebuild
« Reply #375 on: June 18, 2016, 01:11:15 PM »
Oh man we see failures more & more as aftermarket supplies cheap alternative Bill. I use OEM o-rings, pucks etc all the time now.
Good thing it came apart for sure.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #376 on: June 18, 2016, 02:22:24 PM »
Yes,the two split/torn ones around the oil orifice's!
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #377 on: June 18, 2016, 08:26:20 PM »
As I  tell my wife periodically, all things happen for a reason. In this case you were lucky. Keep pushing my friend. You've got 36 days.
« Last Edit: June 18, 2016, 10:27:57 PM by dragracer »
Offline kmb69
« Reply #378 on: June 18, 2016, 10:20:04 PM »
Whoa Billy!  :o
Sounds like the gauntlet has been thrown down!  ;)
You better be busy and... really good along the way!  ;D  ;)  8)
Offline dragracer
  • CB750F Dragbike
« Reply #379 on: June 18, 2016, 10:30:41 PM »
Whoa Billy!  :o
Bill's been chomping at the bit to line up with me. He'll get his first chance at Memphis to show you guys how quick that new motor runs. Likely have the stroker crank in there by that time too. Heck, doesn't matter to me- I ain't skeered. Lol.
    • BentON Racing
« Reply #380 on: June 19, 2016, 04:56:30 AM »
No stroker .......yet! Lol. Chomping at the bit for a 10 second, CONSISTENT race bike! I'm getting closer. I don't like watching. Had some set backs,  some self inflicted, we'll live and learn. I'm planning on kicking that door down in Memphis. New head is in the oven drying as we type this. Shooting for 395-399 lbs and 115 + rwhp. And then we'll see if I can put up or shut up! C'mon, Bill  Using SS wire this time around.
Offline dragracer
  • CB750F Dragbike
« Reply #381 on: June 19, 2016, 08:04:01 AM »
All joking  aside, I'm rootin for ya Bill. I've been feelin your pain brotha and just want to see you make some clean passes. Too much money and time have gone into this bike over the last year without producing results. I appreciate the fact you haven't given up. The numbers will be there as reward for the hard work.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #382 on: June 19, 2016, 11:55:22 AM »
BBQ is on me at interstate one night that weekend ;D
    • BentON Racing
« Reply #383 on: June 19, 2016, 12:01:53 PM »
Amen to that Frank and Medyo!  K. Look forward to it, Bill
Offline POPS 911
« Reply #384 on: June 24, 2016, 06:52:03 AM »
BILL: Do you have a granite table to check for flat surfaces ????? MSP Never put a big BUSA motor together without "gently " putting the head on that block and using a feeler gauge to check for TRUE . A must tool for a engine builder to seal up the [pump] motor for the best power.
« Reply #385 on: June 24, 2016, 07:50:21 AM »
Pops right about a surface plate, I usually give everything a rub on fine emery paper.
I know everyone has their fav's so each to his own, but if you've had sealing issues.... for a few years now I've been using Gasgacinch on my copper head gaskets with SS o-rings. I find it's better than copper spray or anything else I've tried.
    • BentON Racing
« Reply #386 on: June 24, 2016, 08:31:59 PM »
No POP's,  I got a Jim French made for me surface plate, he made me the little one also! Over 30 years ago!  Thanks again Jim!  POP's this one's level! Rick Stetson and Mike Rieck level!  Lol.
    • BentON Racing
« Reply #387 on: June 24, 2016, 10:22:00 PM »
And z cylinder is O ringed with new .045 SS wire 302/304.The head is on and torqued! Went ahead and installed a new .050 copper Cometic headgasket   Valve train and degreeing tomorrow!  Yippee Kai Yeah,  we are coming! Lol, Bill
Frank, did you buy keys with z money? Sorry about your escapades. It'll be ok.
« Last Edit: June 25, 2016, 08:17:10 PM by Bill/BentON Racing »
Offline POPS 911
« Reply #388 on: June 25, 2016, 04:25:09 AM »
Bwaller: I used that "yellow snot" Gasgacinch to seal all the KZ motors and HONDA motors I have, if you want a soft gasket , pan, side or valve cover gasket to never leak use SUZUKI BLACK or go to a TOYOTA dealer part counter and get their BLACK sealer = same stuff....... no leaks for sure. In the old days one of the wrench spinners that worked for my father [1950-60-70 era] had me spray paint copper gaskets with SILVER spray paint both sides [twice] to seal up and to make it easier to remove head if a new problem on those FLAT HEADS MOTORS came up later. The PUMP or that motor needs to be dead on sealed for the best power.
« Reply #389 on: June 25, 2016, 09:49:16 AM »
Billy, it's pretty amazing what you've learned during the resureRection!! Just glad we're all along for the ride. Have you rescheduled with Brian yet?
Offline dragracer
  • CB750F Dragbike
« Reply #390 on: June 25, 2016, 10:18:13 AM »
Bill, so glad its coming together for you. She'll run like a scalded dog this time so be prepared to hang on brother.
As to the lost truck key situation, I remembered my cousin found a key in some bags of compost leaves I gave him. Turns out it was one of the two keys I lost. I loaded up last night   for  trip to Commerce, but when the alarm went off at 5:00am, my mind directed me to the weather forecast of 100 degree temps. I cut the alarm off and rolled over for some shut eye. Lol. Actually I haven't gotten the check yet. It might get here today.
See you in Memphis.
    • BentON Racing
« Reply #391 on: June 25, 2016, 11:22:06 AM »
K, wow,  I mailed it Tuesday, let me know, glad you found your key. It is way hot,108 heat index!
« Reply #392 on: June 25, 2016, 12:27:11 PM »
Those indexes are for sissies LOL Be a real heat man.
Offline BPellerine
« Reply #393 on: June 25, 2016, 12:28:38 PM »
kind of amazing that some guys run no headgasket at all just hi temp silicone,saw it on a 915 Norton and a big bore xs 650,ie 750 kit.good luck bill hope all works well!billp
1978 CB 750K ard and webers
another anfob
    • BentON Racing
« Reply #394 on: June 25, 2016, 08:16:29 PM »
Getting there. Time to check this girls numbers/figure! She's got big jugs now! Ti earings etc.Black wrinkle make up, wow, a sexy girl she is! Lol. Where's the apple pie shine, time to have a shot!
Offline POPS 911
« Reply #395 on: June 26, 2016, 04:40:20 AM »
BILL: With the trueing up and shave down how many number points did that work pickup = will you be able to start that high compression motor [ shaved, o-ringed ] with a on board HONDA starter ??? You hurt your leg at Valdosta kicking that Cobra. Engine builder local gave me a hint on starting shaved head motors = spray a little starting ether in carbs before you crank leg or button or start cart......... remember ST/ET rule must self start. The granite table I use was 4 inches thick and I made a soft wood pine cover to store  for NO NICKS OR DENTS = TRUE FLAT.
    • BentON Racing
« Reply #396 on: June 26, 2016, 05:52:00 AM »
POP'S,  I'll MAKE it work!  Yes a little fuel before starting works wonders,  so does carbs with fuel enricheners like the RS34'S!  Lol,  we getting closer you keep getting closer,  one day you there!! So I keep telling myself,  LMAO,  Bill
« Last Edit: June 26, 2016, 06:02:22 AM by Bill/BentON Racing »
    • BentON Racing
« Reply #397 on: June 26, 2016, 01:09:55 PM »
And z intake shall close at 56 degrees ABDC, I'll take it.Lol. About ready to go back in! Fingers crossed, Bill
Offline dragracer
  • CB750F Dragbike
« Reply #398 on: June 26, 2016, 01:33:54 PM »
Ready to rock and roll. Fresh, big motor with all the right go gas parts and assembled by the Master Wrench
    • BentON Racing
« Reply #399 on: June 26, 2016, 02:10:12 PM »
I'm looking for my clown hat now! Lol, we are entertaining if nothing else!  About to go in!I'm tired, wonder why?  SMH.,Bill
