Author Topic: Australian Bricklayer's Accident Report  (Read 1420 times)
Offline Jonesy
  • Shop Rat
« on: November 06, 2006, 07:45:14 AM »
AUSTRALIAN BRICKLAYER'S REPORT
This is a bricklayer's accident report, which was printed in the newsletter of the Australian equivalent of the Workers' Compensation board. This is supposedly a true story. Had this guy died,  he'd have received a Darwin Award for sure.........
Dear Sir,
I am writing in response to your request for additional information in Block 3 of the accident report form. I put "poor  planning" as the cause of my accident. You asked for a fuller explanation and I trust the following details will be sufficient. I am a bricklayer by trade. On the day of  the accident, I was  working alone on the roof of a new six-story building. When I completed my work, I found that I had some bricks left over which, when weighed later were found to be slightly in excess of 500lbs. Rather than carry the bricks down by hand, I decided to lower them in a barrel by using a pulley, which was attached to the side of the building on the sixth floor. Securing the rope at ground I went up to the roof, swung the barrel out and loaded the bricks into it. Then I went down and untied the rope, holding it tightly to ensure a slow descent of the bricks. You will note in Block 11 of the accident report form that I weigh 135lbs. Due to my surprise at being jerked off the ground so suddenly, I lost my presence of mind and forgot to let go of the rope. Needless to say,  I proceeded at a rapid rate up the side of  the building. In the vicinity of the third floor, I met the barrel, which was now proceeding downward at an equally impressive speed. This explained the fractured skull, minor abrasions and the broken collar bone, as listed in section 3 of the accident report form. Slowed only slightly, I continued my rapid  ascent, not  stopping until the fingers of my right hand were two knuckles deep into the pulley. Fortunately by this time I had regained my presence of mind and was able to hold tightly to the rope, in spite of beginning to experience pain.
At approximately the same time, however, the barrel of bricks hit the ground and the bottom fell  out  of the barrel. Now devoid of the weight of the bricks, that  barrel  weighed approximately 50 lbs. I refer you again to my weight. As you  can  imagine, I began a rapid descent, down the side of the building.   In the vicinity of the third floor, I met the barrel  coming  up. This accounts for the two fractured ankles, broken tooth and several lacerations of my legs and lower body.
Here  my luck began to change slightly. The  encounter with the Barrel seemed to slow me enough to lessen my  injuries when I fell  into the pile of bricks and fortunately only  three vertebrae were  cracked.
I am sorry to report, however,  as I lay there on the  pile of bricks, in pain, unable to move, I  again lost my composure  and presence of mind and let go of the  rope and I lay there watching  the empty barrel begin its journey back down onto   me.  This explains the two  broken legs.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Australian Bricklayer's Accident Report
« Reply #1 on: November 06, 2006, 07:48:12 AM »
 ;D
This bears an uncanny similarity to an episode on Myth Busters.
Offline Jonesy
  • Shop Rat
« Reply #2 on: November 06, 2006, 07:50:22 AM »
That's why I put "supposedly" true... Still, it was too funny not to share.
Offline Rsnip988
« Reply #3 on: November 06, 2006, 11:13:32 PM »
Oh my Word
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #4 on: November 07, 2006, 09:27:38 AM »
The joke started life in the '50s as part of the repertoire of Gerard Hoffnung.
The punch line at the end was "I respectfully request sick leave."
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline mcpuffett
« Reply #5 on: November 07, 2006, 11:27:08 AM »
saw the myth busters episode  ;),   mick.
Offline Jonesy
  • Shop Rat
« Reply #6 on: November 07, 2006, 01:15:46 PM »
Like I said, I figured it was a fib, but funny nonetheless...
But picturing Terry as the bricklayer made it all too believable, Ha, ha! ;D
(just teasin, Terry!)
