Author Topic: Barn find without the barn *UPDATE* $50.00 and loaded on the truck  (Read 9533 times)
Offline dhall57
Re: Barn find without the barn *UPDATE* $50.00 and loaded on the truck
« Reply #50 on: January 09, 2016, 04:27:48 AM »
Used my impact driver(you have to have one to work on these old bikes)to get the side cover off. Going to remove starter while Im hear to be sure its not froze up from sitting so long outside and keeping engine from turning also. Still letting the engine soak a little longer after putting some lube down the plug holes. Nasty behind that cover ???
« Last Edit: January 09, 2016, 04:29:24 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #51 on: January 10, 2016, 06:26:57 AM »
Dwight,
As far as the tank treatment goes, if it were mine, I'd start with the Vinegar treatment for a week, then inspect and if necessary follow up with the Klean and Strip "Prep & Etch" for an hour or 3.  That should have the tank looking good.
Definitely pull the petcock and gas cap and use rubber stoppers to plug the holes.
Quite a nice find and I know she'll turn out nice!
Charlie
Offline dhall57
« Reply #52 on: January 10, 2016, 03:34:38 PM »
The Works really works ;D Still soaking but damn look at the difference :o and this is the rust that came out of tank.
« Last Edit: January 10, 2016, 03:55:50 PM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline oldhatt45
« Reply #53 on: January 10, 2016, 04:11:27 PM »
Whoa!!!
That's a pile of rust!
But the tank is looking good!
Charlie
Offline dhall57
« Reply #54 on: January 11, 2016, 02:48:31 AM »
Thanks Charlie. It was a pretty productive weekend on the old girl ;D Tank is coming along good as you see and after sitting for 5 days with MMO and ATF the motor came FREE kicks over smooth as silk 8) so I hope the motor will be good to go.
Johnie- Looks like the Honda Gods are smiling on me too ;)
« Last Edit: January 11, 2016, 04:13:25 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Johnie
« Reply #55 on: January 11, 2016, 04:49:54 AM »
Yes I would say so hall! Good on you there. I can not believe how good that tank cleaned up. Any issues with pin holes?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #56 on: January 11, 2016, 06:53:23 AM »
...after sitting for 5 days with MMO and ATF the motor came FREE kicks over smooth as silk 8) so I hope the motor will be good to go.
Good news!
Offline dhall57
« Reply #57 on: January 11, 2016, 04:04:52 PM »
No Johnie no issues
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline dhall57
« Reply #58 on: January 11, 2016, 04:28:48 PM »
Good news!
Real good news  Stev-o
I was starting to think maybe she wasn't going to free up. After all had been sitting outside for years uncovered. And even though plugs were still in bike after all that time moisture and dampness had to come into play. The rocking back in forth in high gear was not working like it did with my 750K4. So I decided to take the left side cover off so I could get  direct access to the crank bolt and that did the trick. Im surprised you didnt  here my scream of joy all the way in Texas when it broke loose.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #59 on: January 11, 2016, 04:32:23 PM »
Good news!
Ha!
Offline Restoration Fan
  • My wife will never call me
« Reply #60 on: January 11, 2016, 06:16:30 PM »
Maybe that's what I heard down here in Georgia!  Congrats on getting it free and that tank is cleaning up nicely!  Well done, dhall!
Offline dhall57
« Reply #61 on: January 11, 2016, 06:56:00 PM »
Dumped out the The Works and here is the bottom of tank no bad ;D Found about a 1/2 gallon of Evaporust I didnt know I had and poured it in.Going to let it sit overnight and I think tank will be good to go ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #62 on: January 11, 2016, 07:18:44 PM »
How much of The Works did you buy to put in there?  I have an old 750 tank that I'm just fooling around with but it will eventually clean up.  I'm thinking of buying some of that to put in there but I'd love to know how much you used.
Offline Tews19
  • I am no
« Reply #63 on: January 12, 2016, 06:44:09 AM »
DH, look closely at the rust spots. Looks like maybe some metal was eaten away. Tank looks great but to play it safe I would line it. For 40 bucks it's worth saving headaches later on.....
« Last Edit: January 12, 2016, 10:15:12 AM by Tews19 »
1970 Honda CB750 survivor.
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« Reply #64 on: January 14, 2016, 05:41:27 AM »
I have used 'The Works' in the past....but, I have always used a baking soda mixture directly after in order to neutralize the acid.
Just a thought....
Offline Kenzo
« Reply #65 on: January 14, 2016, 09:20:59 PM »
I just saw it for the first time and still grinning ear to ear. :)
I'm sure most of you have seen this but for those who haven't...enjoy!
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
DH
« Reply #66 on: January 15, 2016, 05:16:00 AM »
Kenzo
I knew that there had to be a place where they all went...Now we know. Watching that is torture!! ;D
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #67 on: January 15, 2016, 09:40:01 AM »
Kenzo
Mine would fit right in
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline dhall57
« Reply #68 on: January 17, 2016, 04:09:49 PM »
My unheated garage was a cold today. But I tinkered with the bike a little took seat off and removed the battery and air filter.
Seat looks to be pretty much a lost cause. Hope to take carbs off bike next week. Throttle is stuck so Im sure they are in rough shape to.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #69 on: January 17, 2016, 04:25:23 PM »
I think Dave in Ohio has a 500 seat for sale, will look for the thread.
I like using a petroleum-based cleaner on dirty, rusty areas of the bike [rather than water].
Offline dhall57
« Reply #70 on: January 17, 2016, 04:38:53 PM »
Have not done any cleaning on bike of yet. In case you couldn't tell ;D
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
DH
« Reply #71 on: January 17, 2016, 06:36:23 PM »
http://www.ebay.com/itm/Honda-CB500-K1-1971-1974-Replacement-Seat-Cover-Silver-Painted-Logo-strap-/251394784835?hash=item3a884bfe43:g:tV0AAMXQDfdRqPwN&vxp=mtr
if you decide to recover, this seller has good ones, less the chrome strip. I have a correct one for my 550. Decent price/quality.
Offline Scott S
« Reply #72 on: January 18, 2016, 02:28:34 AM »
Just a thought....
 This +1
 And dry it completely. I swish around some denatured alcohol to suck up the water from the tank seams, etc. Compressed air and/or a heat gun to dry it some more. Once dry, swish around some Marvel Mystery Oil to protect it until you add gas.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline mycoal
« Reply #73 on: January 18, 2016, 07:27:49 PM »
Man, I absolutely love seeing dirty pictures of bikes. Especially upclose shots of individual compartments and sections. It's almost a perversion of mine. Can't wait for the after picks. That battery compartment doesn't look too bad, except for maybe some rotten rubber terminal boots.
1978 CB750K with 1977 GL1000 front end
Offline dhall57
« Reply #74 on: January 19, 2016, 02:26:49 AM »
Easy boy easy don't get to worked up! Remember this is a G rated forum ;D
« Last Edit: January 19, 2016, 02:39:05 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
