Author Topic: Caliper rebuild  (Read 722 times)
Offline rappz7
  • Bikes dont leak oil, they mark their territory
Caliper rebuild
« on: December 22, 2015, 10:33:27 AM »
like the title says im rebuilding my bikes brake caliper. I have a 1979 cb650 and I broke down the caliper for inspection, clean, and paint and found that most of the seals are on their way out and need to be replaced. Ive done some searching for a re-build kit but have been unsuccessful. Does anybody know where i can get my hands on a rebuild kit for my bike?
Are there kits from other years/models that will work for my caliper? Thanks and as always your input is appreciated.
Offline mrfish2
  • I might be a
Re: Caliper rebuild
« Reply #1 on: December 22, 2015, 10:48:35 AM »
Z1 Enterprises, Partzilla, Parts n More, VintageCB750; they have what you need.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline tlbranth
Re: Caliper rebuild
« Reply #2 on: December 22, 2015, 11:39:41 AM »
You can get replacement stainless steel caliper piston from Wingovations. 20% off 'til year's end.
http://www.wingovations.com/stainless-steel-brake-pistons/4588600239
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline rappz7
Re: Caliper rebuild
« Reply #3 on: December 23, 2015, 01:09:01 PM »
Thanks for the point in the right direction but I didn't find anything for my year specifically. Not unless other model cbs use similar gaskets and seals?
Offline rappz7
Re: Caliper rebuild
« Reply #4 on: December 23, 2015, 01:12:38 PM »
Thanks for the tip. Ill be sure to check it out.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Caliper rebuild
« Reply #5 on: December 23, 2015, 02:28:37 PM »
Parts and More has all the seals for the master cylinder and caliper (including the piston) for a 79 CB650.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline tlbranth
Re: Caliper rebuild
« Reply #6 on: December 23, 2015, 04:30:31 PM »
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline mrfish2
  • I might be a
Re: Caliper rebuild
« Reply #7 on: December 23, 2015, 08:12:47 PM »
Did you even look at any of the sites?
Partzilla:
http://www.partzilla.com/parts/detail/honda/HP-45215-533-004.html
VintageCB750:
http://www.vintagecb750.com/products/2/chassis-brakes/42/brake-caliper-rebuild-kits-brake-caliper-pistons-bleed-screws
Parts n More:
http://www.partsnmore.com/parts/honda/cb650/?filters%5Bfitting%5D=custom&filters%5Bpage%5D=2
Come on man, you gotta dig for the good stuff  ;)
1980 CB650C - Sold
