Author Topic: New to motorcycles period  (Read 560 times)
Offline ThatWolfKid
« on: December 22, 2015, 12:23:22 PM »
Hiii, just got my first bike and it wasn't perfect but I think I made it worse.
It's a cb350F in that basic red with noting special on it
Came with a Mac 4-1 (bummer)
I don't plan on keeping it original to all the og guys I know it will lose value but I want to build it my self and that'll be worth more to me
Looking forward to the responses
Just one thing that I hope someone can help me with real quick
So I was cleaning it a bit and removed the battery, when I put it back on I made sure not to switch sides and remove/connect the right wires first....I had my headlight remove at the time and when I went to go check to see if the lights would turn on they didn't. OK so I thought maybe the battery just need a lil juice so I took out the bike to go kick start when outside the neutral and oil lights came on before I kickstarted it so I figured the headlight being off had something to do with the turn signals being off still and put the problem aside in my head.....soo I got to start it anyways and it does but as usual its has a rough idle and I just try and keep it on a bit just so that it gets moving once in a while until  y helmet comes, its idles on and off until it won't turn back on then I noticed like an idiot I forgot to turn on the petcock so I turn it on and I could see gas rushing down and was like @#$% this thing had no gas in the carbs.... THE PROBLEM IS  now when ever I turn on the petcock gas immediately pours out I'm assuming are tubes for when it floods under each carb and its funny cause it'll only come out two of them and its the two on the opposite side of the kick stand. So I'm thinking the other two are clogged ...so did I ruin my bike already ? Nooob
Offline calj737
  • I refuse...
Re: New to motorcycles period
« Reply #1 on: December 22, 2015, 01:48:22 PM »
Welcome. No, you didn't ruin anything. Follow Flybox's advice in your other post. The only time Forum Nazis yell at Newbs is when they buy cheap carb rebuild kits  >:( >:( >:( >:(
Offline mrbreeze
  • Not your average
« Reply #2 on: December 22, 2015, 02:00:35 PM »
;D ;D ;D ;D........forum Nazis!!!
MEMBER # 257
Offline ThatWolfKid
« Reply #3 on: December 22, 2015, 02:36:21 PM »
Yeah I'm one of those guys that buys cheap rebuild kits...I didn't know honest I thought KEIHIN stopped making them?
