Author Topic: EMGO GAs Shocks  (Read 1757 times)
Offline spiritof67
EMGO GAs Shocks
« on: December 23, 2015, 08:49:22 pm »
I have a duffel full of suspicion about a $185 set of "high peformance" shocks, especially EMGO. But are they in fact any good?
Re: EMGO GAs Shocks
« Reply #1 on: December 24, 2015, 09:31:47 am »
where are you seeing these?...thinkin they usually sell for about $85...and for that kind of money, they are just ok.  I bought a pair for $25 at a swap meet and used them for a short time.  I found them slightly better than typical 70's era Honda stock shocks.
Re: EMGO GAs Shocks
« Reply #2 on: December 24, 2015, 10:00:10 am »
Garbage. Okay if you need a placeholder.
Offline Tintop
Re: EMGO GAs Shocks
« Reply #3 on: December 24, 2015, 10:01:20 am »
+1 I'd pass on Emgo, and look into Hagon's for that kind of money.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline turboguzzi
Re: EMGO GAs Shocks
« Reply #4 on: December 24, 2015, 11:48:30 am »
yss...
Offline simon#42
  • liverpool
Re: EMGO GAs Shocks
« Reply #5 on: December 24, 2015, 01:51:53 pm »
not even a good looking placeholder , have a look at ikon have had suprisingly good results with them
not used the yss shocks yossef , they seem too cheap to be any good ......... unless you know better !
Re: EMGO GAs Shocks
« Reply #6 on: December 24, 2015, 02:11:27 pm »
ok, I just noticed this was in hipo/racing forum...and so yeah, if that is your intention, they are garbage
Offline Tintop
Re: EMGO GAs Shocks
« Reply #7 on: December 25, 2015, 05:44:55 am »
77 CB550 Cafe build
Offline turboguzzi
Re: EMGO GAs Shocks
« Reply #8 on: December 25, 2015, 10:34:54 am »
rene used yss on his son's race bike and they sounded happy. they do seem to have a few quality levels though.
http://www.yssusa.com/show_detail.php?brand_id=6&&model_id=18
would skip the bravo for sure....
i had old restored konis in my racer, they are indeed fine. only problem is that being a bit old design, they mount the damper part on the bottom, so the first few mm of travel, piston can be swimming in froth instead of clean fluid. more modern designs of pressurized ones (i am talking about non bladder/reservoir type) have the damper on bottom so piston spends more time in pure fluid = more control. that applies of course not just to yss.
« Last Edit: December 25, 2015, 10:40:59 am by turboguzzi »
Offline Tintop
Re: EMGO GAs Shocks
« Reply #9 on: December 25, 2015, 05:39:02 pm »
I have the "Z" version TG, only complaint was the initial springs they supplied to me were too stiff for street use.  Likely would have worked great on the track.
77 CB550 Cafe build
Offline turboguzzi
Re: EMGO GAs Shocks
« Reply #10 on: December 26, 2015, 07:00:48 am »
TT, how much they go for on your side of the pond?
Offline Tintop
Re: EMGO GAs Shocks
« Reply #11 on: December 26, 2015, 08:11:05 pm »
I got them in late 2010 TG, they were under $500 Cdn for the pair (including shipping / duty / taxes).  However the Canadian $ was strong then, today I'd have to add about 30%. :(  Ikon's would have been less but were on long back-order, and the Hagon's that were available then could not be re-built.
77 CB550 Cafe build
