Author Topic: Sprocket Guard  (Read 853 times)
Offline spiritof67
Sprocket Guard
« on: December 23, 2015, 08:55:04 PM »
Since we now have very strong drive chains, probably 3x the tensile strength we had in the 1970's, do you still need the case protector style sprocket cover? If so, which between the '69 and '76 style is recommended? Is there any need for that frisbee on the rear sprocket either?
Offline kmb69
Re: Sprocket Guard
« Reply #1 on: December 23, 2015, 09:01:34 PM »
The "Frisbee" on the rear wheel is to hold your chain when dropping and replacing the rear wheel.
I should add, it's not necessary.
« Last Edit: December 24, 2015, 06:51:12 AM by kmb69 »
Re: Sprocket Guard
« Reply #2 on: December 23, 2015, 10:25:07 PM »
if you got agood new chain...#$%* that junk
Offline spiritof67
Re: Sprocket Guard
« Reply #3 on: December 28, 2015, 02:22:14 PM »
Thanks.  My K0 didn'tcome with one,nor did it have the "case saver" inside the primary cover.
