Author Topic: GL1000 FORKS FOR THE CR 750 REPLICA BUILD  (Read 1251 times)
Offline captaink
« on: December 26, 2015, 11:20:52 PM »
Hi All,
I'm looking for a suitable fork set up for the CR 750 project.
The general idea would be to go for a Goldwing set up ie GL1000 1975-1977 with the 37mm dia. stantions.
Am I correct that this year would have the trees that fit straight onto the 1977 CB750 headstock ?
I was looking at also using the same GL front hub, twin disks set and a new spoke wheel ( the whole front end )
Any info appreciated or other options considered.
Cheers Keith
CR750 Replica Honda colours
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
Rickman 750 project
CR 750 dick Mann project
1964 series 1 E type jaguar
Gt40
" Greedy I Know "
Re: GL1000 FORKS FOR THE CR 750 REPLICA BUILD
« Reply #1 on: December 27, 2015, 10:31:50 AM »
Keith,
The 1975-76 GL1000 front is a direct fitment swap to the CB750 headstock. The shell hub is identical BUT the GLRim is aluminum, AND the brake rotors have a different offset.
If you do not want to rebuild a wheel and prefer the lighter aluminum, use the stock GL wheel. You can also save unsprung weight by thinning the rotors or using EBC floating rotors as replacements.
« Last Edit: December 27, 2015, 04:14:39 PM by CB750 Cafe Racer Fan »
Offline dusterdude
« Reply #2 on: December 27, 2015, 10:41:05 AM »
I may be wrong but,i thought 75-76 were a direct swap,not 77
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline captaink
« Reply #3 on: December 27, 2015, 12:28:54 PM »
Thanks for that info. The set up you have in the photo is as I would like.
If I obtained a 75-77 complete gl1000 front end that would be OK.
Of course everything would be rebuilt but this will fit and work well I presume ?
Would you need the fork stabiliser , I assume so ?
Cheers Keith
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
Offline BPellerine
« Reply #4 on: December 27, 2015, 03:47:22 PM »
yep 75,76
1978 CB 750K ard and webers
another anfob
« Reply #5 on: December 27, 2015, 04:14:20 PM »
Yes correct about the 75-76. The 77 goes to Comstar I believe.
Offline captaink
« Reply #6 on: December 28, 2015, 01:28:09 AM »
75-76 it is then
Thanks all
Keith
Norton CS1 1930
Norton 16H 1924
Rickman 750 project
Gt40
" Greedy I Know "
