Author Topic: What is it?  (Read 2226 times)
Offline Steve F
Re: What is it?
« Reply #25 on: December 28, 2015, 09:45:29 AM »
A heat exchanger?
Offline terecha
Re: What is it?
« Reply #26 on: December 28, 2015, 02:10:27 PM »
exhaust jet pump. Quite popular in the Europe. Makes that fumes go faster.
Offline Bailgang
  • Scott
  • Indiana
Re: What is it?
« Reply #27 on: December 28, 2015, 05:25:27 PM »
Some sort of pulse jet?
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: What is it?
« Reply #28 on: December 28, 2015, 05:27:14 PM »
An inline filter with differential ports to monitor filter condition?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: What is it?
« Reply #29 on: December 28, 2015, 05:57:28 PM »
a ditch pump flow meter scottly ?
Pretty close, Simon, but it would also work with your 1/2-of-a-Volkswagen rocking-horse. :P ;D
It is indeed a part of a flow meter; it's a laminar flow element, calibrated to flow 100 CFM when the pressure differential between the two ports is 8" of water. The element itself is made from many very small tubes of .001" wall stainless steel, which makes it look something like a lens when looking through it.
Offline simon#42
  • liverpool
Re: What is it?
« Reply #30 on: December 29, 2015, 04:08:38 PM »
that half a vw has finally made over 100 hp without exploding , well its not exploded yet . back on the dyno in two weeks to try and kill it again .
Offline kmb69
Re: What is it?
« Reply #31 on: December 29, 2015, 04:26:29 PM »
Very kool! Did you get the Calibration Curve Table that came with it from the factory?
Re: What is it?
« Reply #32 on: January 01, 2016, 07:09:14 PM »
Hey Keith, no, sadly I didn't get the original curve table, but since the calibration tag expired over 30 years ago, it might not be accurate anyway? I could send it in for re-calibration with a new table, but it would probably be very expensive. I was going to use it directly attached to the bottom of a 750 head to measure flow, until I realized how sensitive to dust and debris the flow element is, so I will use it to calibrate a DIY flow-bench; it should still be within +/- a few percent, and weather conditions still need to be factored in to correct to standard measurements. My dyno has a weather station, but I will have to manually log everything by hand, then crunch the numbers. I'm not so much concerned about absolute flow as I am with a measurable improvement in flow, and then how it acts on the dyno. ;D
