Author Topic: Oil Guide on CB750K4-8  (Read 581 times)
Offline teamtiger21
« on: December 28, 2015, 07:42:58 AM »
It appears that the crankcase oil guide #15621 300 000 does not exist on K4-8? Is this correct?
Re: Oil Guide on CB750K4-8
« Reply #1 on: December 28, 2015, 08:12:58 AM »
K6-8, and F's do not have this part.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: December 28, 2015, 08:34:55 AM »
This would only be required on the earlier models if you were still using the stock chain oiler (aka oil slinger), correct? If the stock chain oiler at the front sprocket shaft were plugged and or eliminated then the oil guide is unnecessary?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: December 28, 2015, 08:37:26 AM »
That's right. I've pitched it on several rebuilds. Lube the chain manually. With an Oring chain, which they didn't have back then, the auto luber is unnecessary.
Offline teamtiger21
« Reply #4 on: December 28, 2015, 11:47:26 AM »
Thanks for the confirmation!
« Reply #5 on: December 29, 2015, 08:22:47 AM »
YW  :D
