Author Topic: CB400f bolt list  (Read 1756 times)
Offline flyonly
CB400f bolt list
« on: December 28, 2015, 01:44:10 PM »
Hi
I am looking at replacing all my bolts with stainless steel ones. Has some one been through the exercise of working out all the bolt sizes and lengths?
I have tried to find the rear shock acorn nuts.  I did find some 10mm nuts x 1.00mm but they are no good. I think I need 1.25mm
Any help appreciated
Sent from my iPad using Tapatalk
Offline Flyin900
Re: CB400f bolt list
« Reply #1 on: December 28, 2015, 02:06:47 PM »
The shock nuts are still available from Honda for a few bucks each. There are resellers on EBay that sell partial and full SS bolt kits for the CB 400F.
You can also do a bolt count off a parts fiche if no one has the correct sizes and quantities. I did that a few months back and found a local wholesaler with a very good pricing that made it worth the extra work.
The EBay ones are a reasonable deal and saves all the sourcing and work if no one else has the count. I didn't save the paper that I used for the purchase so can't help you, although there are 3-4 main sizes and just a few 50mm and 60mm ones needed.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline przjohn
« Reply #2 on: December 28, 2015, 03:01:51 PM »
When you say, "All The Bolts" do you really mean, all? Including all case bolts, engine mounts, caliper, meter mounts, doohickey, and thing-a-ma-bob fasteners? Or, do you mean certain bolts for asthetics? You can replate many bolts and though not SS they will look new.
Offline flyonly
« Reply #3 on: December 28, 2015, 07:42:03 PM »
I guess I should have been more specific. I was planning to do it in two goes.  The chassis bolts and anything fitted to it. The second go was going to be the external engine bolts.
I am living in Australia and the bolt kits look great on eBay but the freight can put them over the top.
I have had some bolts replated e.g. Swing arm bolt just because I didn't think I could get on of them new
Offline basic
« Reply #4 on: December 28, 2015, 10:17:12 PM »
I ran across an engine bolt list today while looking for carb bolt sizes. I'll try and see if I can hunt it down and report back. Otherwise I have a stainless bolt set in the mail to me - I will take inventory of that when it arrives and post the sizes in the set.
Offline basic
« Reply #5 on: December 31, 2015, 09:58:35 AM »
Well, didn't have any luck finding the info that I ran across a couple days ago, but I did receive my stainless bolt kit from stainless cycles.
Here are the bolts included:
*SHCS = Socket Head cap Screw
Cylinder Head cover (SHCS)
25 - M6 x 1 x 35
Oil Pan (SHCS)
11 - M6 x 1 x 40
11 - M6 Washers
Points Cover (Oval Head)
2 - M6 x 1 x 30
Right Crank Case Cover (Varies)
7 - M6 x 1 x 40 (SHCS)
2 - M6 x 1 x 55 (SHCS)
2 - M6 x 1 x 60 (SHCS)
1 - M6 x 1 x 90 (SHCS)
2 - M6 x 1 x 16 (Oval Head)
1 - M6 x 1 nut
1 - M6 Washer
Left Crankcase Cover (SHCS)
4 - M6 x 1 x 35
Alternator Cover (Varies)
2 - M4 x 0.7 x 12 (Oval Head)
3 - M6 x 1 x 16 (SHCS)
2 - M6 x 1 x 40 (SHCS)
Starter Motor (SHCS)
2 - M6 x 1 x 30
Totals overall:
2 - M6 x 1 x 30 (Oval Head)
2 - M6 x 1 x 30 (SHCS)
29 - M6 x 1 x 35 (SHCS)
20 - M6 x 1 x 40 (SHCS)
4 - M6 x 1 x 55 (SHCS)
12 - M6 Washers
9 - M6 x 1 nuts
Offline flyonly
« Reply #6 on: December 31, 2015, 02:47:16 PM »
Thank you so much. Has anyone got the list of the bolts for the frame, wheels etc?
Offline Jore
« Reply #7 on: December 31, 2015, 03:43:50 PM »
This is quite the list, thanks for taking the time to share it.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
