So I'm finally getting to the fun wiring stage of my Super Sport build. I'm working in the junction box in the front of the frame and came across a wiring issue I don't remember taking apart (should have taken pictures in the beginning...)
So the Green arrow is pointing to a connection that I think I did right. It's a brown wire with a blue line and a yellow sleeve, coming from the harness. The male I plugged into it came from the left hand controls and had a little yellow band around it.
The issue I'm having is the wire I have circled in red. It's a second brown/blue wire coming from the harness. I also had a little matching male-to-male brown/blue jumper wire that I have plugged into it. I'm assuming it plugs into the female off the harness...but now what do I do with it?
The only thing I can think of is to plug it into the junction of 4 black wires that I have pointed to with a blue arrow. I poked through a few threads and thought I saw someone suggest that.
If the pic is too small, open it in a new tab. It's pretty big.
Any thoughts?
Also, Does anyone have a wiring diagram specific to the 75/76 F bikes? I can only find them for 77
