Been in touch with carpy he said try shaving the fins down on the sump .??
Don't worry about the small clearance to the sump, as long as its not touching its all good...
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
I like my pipes as tight to the engine as possible, lots of bikes are set up like this, just use a bracket to take the pipe off the sump, thats all that needed, don't grind fins off the sump, stupid advice...
![Shocked :o](http://forums.sohc4.net/Smileys/default/shocked.gif)
