This will probably cause more confusion, but hey, better than a blown engine. I will do some more measurements to make sure everything checks out dim specs wise. The outer plate height is the only thing I checked earlier and it was 9.6mm, exactly what the specs say. I didn't find any specs for plate thickness in the catalog (first post of this thread) but the breaking force(?) FB in the catalog is listed as 12500 N min (12.5kN?). My guess is that its the tensile strength, but someone correct me if I'm mistaken. That value for the G68HPF-2 is 13000 N min (13kN?). Then I found this in another thread when I was searching for the same value for stock chains
EDIT: Image removed.
PLEASE tell me I'm doing something wrong, but the way I read it, both the above chains appear to be below that value.
