Author Topic: Padawan seeking Jedi Night (cb350 four)  (Read 11566 times)
Re: Padawan seeking Jedi Night (cb350 four)
« Reply #25 on: January 07, 2016, 08:28:52 AM »
valve clearance is in-between .005- and .006
Valve tappet clearances
Intake @ .002"
Exhaust @ .003"
Offline Dos
  • Owner of a cb350f
« Reply #26 on: January 07, 2016, 10:24:27 AM »
Right. I'm going to check my valve clearance and timing and points gap. That is all the General maintence I can do for now since I don't have a carb sync tool. Is there another way to sync carbs.. Probably not but I'm thinking that maybe it started knocking after I tuned it up once I got it back due to a poor carb sync.
« Reply #27 on: January 07, 2016, 10:53:31 AM »
You can get them in the ballpark ..rod synching them...use a drill bit.
 Read up on that..and set your valves.
Offline Scott S
« Reply #28 on: January 07, 2016, 01:08:55 PM »
 You can adjust the cam chain, too.
 I'd buy or borrow a vacuum gauge set. Do the 3K mile tune up and sync the carbs. You may be surprised what that will get you.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Dos
  • Owner of a cb350f
« Reply #29 on: January 11, 2016, 10:33:59 PM »
Yeah I am going to do all the tuneups I just got depressed with the bike..
I also have a creeping suspicion though that these guys that touched my bike may have not done a good job putting the engine back together so it would be nice to have someone help out and see if the tuneup really would fix the problem.
If anyone is in NJ or around feel free to message.
Offline DaveBarbier
« Reply #30 on: January 12, 2016, 01:58:53 AM »
...so it would be nice to have someone help out and see if the tuneup really would fix the problem.
I think you think the 3k mile tune up is more of an investment in time than it really is.
Offline camelman
  • Man... Myth... Legend
« Reply #31 on: January 12, 2016, 11:44:04 AM »
I listened to the videos again and the sounds the engine makes are odd. When it's cold, everything sounds fine. After warming up a bit it has that noticeable knock. Your camera might be amplifying certain sounds too, so what I'm hearing might not be accurate. I think you should get a buddy who knows engines to take a look at it, or even take it back to the mechanic who did the work on it.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Dos
  • Owner of a cb350f
« Reply #32 on: January 13, 2016, 10:20:53 AM »
yeah that's what I'm saying it would be cool if someone who knows this engine after I do the tuneup they can still take a listen and say yeah you were just being a dingus it's fine or.. o yeah tuneup made the bike run alittle better but that knocking sounds alittle weird still.
« Reply #33 on: January 13, 2016, 10:35:39 AM »
So did you at least set the valves yet..should only take 1/2 hr..
 Rod synching the carbs  about 40 minutes.. Maybe a bit longer getting airbox on..
 At least try to fix it instead of hoping for an internet solution..
 I mean your valves have around triple the clearance they should have..thats going to make some noise.
Offline Scott S
« Reply #34 on: January 13, 2016, 01:48:24 PM »
 I still don't hear anything but a bad tune up and sync. Maybe there is something more, but you'll never be sure until you tune it properly and see what happens.
'71 CB500 K0
'81 Yamaha XS650
« Reply #35 on: January 13, 2016, 01:58:33 PM »
+100
Offline Dos
  • Owner of a cb350f
« Reply #36 on: February 17, 2016, 09:01:43 AM »
Hey guys!
I am going to be working on the bike this weekend it seems alittle warmer.. for now!
IN the event that regular maintenance can't fix this and it is a minor engine related problem.. is there anyone that can help?
Just want to be prepared.
Offline 540nova
« Reply #37 on: February 17, 2016, 09:44:55 AM »
I'm in south Jersey, where are you? Maybe I can help
Offline 540nova
« Reply #38 on: February 17, 2016, 09:46:45 AM »
Disregard, I see you're in Montclair. If you haven't already, get a Clymer manual or Honda service manual, and take it step by step
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #39 on: February 17, 2016, 09:53:35 AM »
Hope you make some progress this weekend, and try to take it one step at a time. I know sometimes all you can think about is everything at once which seems like a monumental task, but the people on this forum really know their stuff. I also have 4 Genuine Honda carburetor rebuild kits should you need them.
Spencer
Offline Dos
  • Owner of a cb350f
« Reply #40 on: March 08, 2016, 06:09:17 PM »
Hey guys,
So I had time to do the tuneup.. I checked my points gap and my timing and fixed that but I am having some trouble with my valve clearance.
Everytime I go to T1.4 and check my valves there seems to be only play in either the exhaust or intake not both.. This leads me to believe that my head may have gotten warped.. again if there is anyone around the Northern Jersey NYC region I'd gladly pay alittle bit for a tuneup and evaluation. I am 65% sure that this might be internal engine problems due to a #$%*ty mechanic but I can't make this decisions with the small amount of knowledge and not even a full tune up
Offline Dos
  • Owner of a cb350f
« Reply #41 on: March 08, 2016, 06:11:18 PM »
I've been paying insurance on a bike that is sitting and rusting now.. I desperately need help and wish to ride my bike this season because I have missed out the past two.. If I can't get this beautiful gem working I am going to have to sell ;( and I don't want to do that
« Reply #42 on: March 08, 2016, 06:39:24 PM »
Hey guys,
if you are checking #1 cyl exh and intake for play, and you only have play in one of these....rotate the crank 360 deg and check again.,
....or leave it where it is and see that there is play in both the intake and exhaust of #4.
Offline Dos
  • Owner of a cb350f
« Reply #43 on: March 08, 2016, 09:33:55 PM »
but if the rocker arm head is warped I will never know the truth I need help from someone who knows the bike
Offline Dos
  • Owner of a cb350f
« Reply #44 on: March 09, 2016, 11:55:32 AM »
Okay. I only say warped head because when i rode it back from brooklyn it was getting very hot and smoking. I feel that may have done it.  I don't know though guys I think I am throwing the white flag up here and being a lazy ass.
nwwa
« Reply #45 on: March 09, 2016, 12:14:22 PM »
You've been given a ton of very helpful and constructive advice already, yet seem insistant on ignorning it.
You bought an old bike, your options are pretty simple.... Bite the bullet, humble yourself, get a service manual and read up, roll up your sleeves, and figure out how to work on it or roll the dice with mechanics.
« Reply #46 on: March 09, 2016, 12:22:37 PM »
That doesn't mean it got hot enough to warp the head.  These are 40+/- year old bikes.  smoking, leaking oil, running rough....find me one that didn't need some tuning (or more) after it was purchased by someone on this forum  ::)
So...did you get the valve lash dialed in yet?
Offline Dos
  • Owner of a cb350f
« Reply #47 on: March 10, 2016, 09:17:07 AM »
Just like my x girlfriends dad said " never ever ever ever give up!"
I'm going back into it I will never give up!
Offline Dos
  • Owner of a cb350f
« Reply #48 on: March 10, 2016, 10:35:27 AM »
My feeler gauge broke in the #$%*ing thing Jesus #$%*ing Christ why God
« Reply #49 on: March 10, 2016, 11:06:11 AM »
yeah..if it broke, you might be a little on the tight side.
itll fish out.  take your time.
