Author Topic: Rust on cam lobes  (Read 1616 times)
Offline beemerbum
Rust on cam lobes
« on: January 07, 2016, 10:13:58 am »
In tearing down a barnfind motor, I found very slight rust on the cam lobes. The rest of the
 steel parts are rust free. Can I remove the rust on the lobes using fine steel wool? Is the cam still functional?
Re: Rust on cam lobes
« Reply #1 on: January 07, 2016, 10:18:32 am »
I dont know for sure, but isnt there a coating of some sort on the cam to prevent wear?  or is it just on the rocker?
If so, i'd be worried the rust was into/through the layer.  Removing it might create a pitted area increasing wear on the rocker.
Got a picture?
Offline Old Scrambler
« Reply #2 on: January 07, 2016, 10:30:49 am »
Mild 'flash' rust on an OEM unit can be removed with a brass brush and some WD-40 or plain oil..............don't be afraid of a mild pit or two.........it will hold oil for better film-protection when in contact with the rockers.  HOWEVER........if the rocker pads are worn they should be replaced.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: January 07, 2016, 11:37:45 am »
 I've used fine scotchbrite and WD40 with no problems.
Offline camelman
  • Man... Myth... Legend
« Reply #4 on: January 09, 2016, 10:34:21 am »
I've found that an oily rag can lift flash rust off a hardened surface like a cam. Those cams have way more surface area than is really needed too, so a minor pit here or there shouldn't be an issue.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #5 on: February 03, 2016, 10:18:27 am »
How do you measure rockers for wear? Or, is it just a visual inspection?
« Reply #6 on: February 03, 2016, 10:46:51 am »
Visual inspection.
 I have seem chrome flaking off, usually on the edges. Not good if you can feel marks with your finger/nail. You will see where the rocker arm pads have been in contact with cam. No problem as long you will not feel it.
Offline calj737
  • I refuse...
« Reply #7 on: February 04, 2016, 04:38:25 am »
Use micrometers on the peak of the lobe to determine any side-to-side wear across the lobe. You'd be surprised at how "slanted" the lobes can be if worn. I bought a used 650 cam that had over 0.03 of wear and was sold as in "mint" condition. The rocker faces too should be mic'ed.
