Author Topic: How to test starter  (Read 3639 times)
Offline kingjess25
How to test starter
« on: January 10, 2016, 04:26:23 PM »
Hi guys, my solenoid clicks but the starter doesn't move. I want to jump the starter directly to test it but have no idea how. Can someone post pics on where I should connect the wires to jump it? Does it have to be removed from the bike? So far I've only removed the starter cover and now I'm stuck.. 1975 cb750
Sent from my SM-N910T using Tapatalk
Offline dusterdude
Re: How to test starter
« Reply #1 on: January 10, 2016, 04:42:09 PM »
Turn the key on,take a screwdriver and jump across the 2 large terminals on the solenoid/relay.the starter should turn over.if it doesnt,starter is shot or there is a wiring issue downstream
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline kingjess25
« Reply #2 on: January 10, 2016, 04:51:33 PM »
I tried but nothing happened. It could be my wiring, that's why I wanna test the starter directly
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: January 10, 2016, 05:04:09 PM »
Shorting the solenoid like that eliminates the wiring as a problem, for the most part.  At that point you're feeding +12v directly into the starter's main lead, it should spin at that point.
Sure your battery isn't dead?
mystic_1
- John Augustus Shedd
Offline kingjess25
« Reply #4 on: January 10, 2016, 05:05:16 PM »
Battery is good I even tried my cars battery. Solenoid just clicks when I press the start button
Offline kingjess25
« Reply #5 on: January 10, 2016, 05:07:58 PM »
One thing I'm unsure about is one of the wires, from the solenoid it is green/red but my new wiring harness doesn't have that color so I hooked it up to the black wire since it was paired with the yellow/red.
Offline Restoration Fan
  • My wife will never call me
« Reply #6 on: January 10, 2016, 05:44:38 PM »
I highly recommend this video.  I think Max does a great job with his diagram of showing how the various components work in layman's terms.  But if you just want the demonstration of how to test the starter, jump to the 5:00 mark of the video.
Offline kingjess25
« Reply #7 on: January 10, 2016, 06:33:27 PM »
Wow, that helped a lot! I think I may know the problem. I realized that I have nothing connected to the other solenoid lead. I'm not sure if this green wire is supposed to be the ground wire for it? I've looked at multiple diagrams but couldn't figure it out
« Reply #8 on: January 10, 2016, 06:52:41 PM »
You should be able to just connect the positive to the post and then the ground wire to the body of the starter like Max did in that video.  If you do that, be aware that it'll jump as it starts to spin.
If you do so, it'll let you know whether or not the starter itself is good.  Once you know that, then you can start to diagnose where else the issue might be if the starter proves to be ok.
Edited:
You can ground the solenoid to the frame or to the negative of the battery, if necessary.  I grounded mine to the frame.  Just make sure that you have a clean connection to bare metal.
« Last Edit: January 10, 2016, 06:55:49 PM by Restoration Fan »
Offline kingjess25
« Reply #9 on: January 10, 2016, 06:54:09 PM »
Thanks a lot sir! I got it to work! It was just my wiring. One last question, I've seen diagrams requiring a fuse from battery to the solenoid, is this necesarry?
« Reply #10 on: January 10, 2016, 06:57:27 PM »
No it's not necessary.  My solenoid connects directly to the positive on my battery.  As a matter of fact, I don't know that I've seen a fuse between the solenoid & the battery on a diagram before.  I don't doubt that some do it but you don't have to.
Offline kingjess25
« Reply #11 on: January 10, 2016, 06:59:02 PM »
Ahh ok. Yeah, I've seen diagrams with and some without. But I guess it'll do without it.
« Reply #12 on: January 10, 2016, 07:02:35 PM »
I helped a buddy get his 75 CB750 going recently and his wiring diagram didn't call for it either.
If you have the standard SOHC wiring system, you're going to have 3 fuses.  But those are in the fuse block and aren't set up to be between the solenoid and the battery.
Offline mystic_1
  • 1970 CB750K
« Reply #13 on: January 10, 2016, 07:22:37 PM »
heh OK didn't know you were starting from such as disassembled state.
On the big posts for the solenoid (which is just a big electrically-actuated switch), one connection is for the starter lead, the other connection is for the positive battery cable, which connects directly to the positive battery post.  Do you have this?
For the small connections to the solenoid, runs to the starter button (yellow+red) (which provides ground) and the other connects to +12V from the harness (black).  Looks like you've got those hooked up right, but I would recommend you get rid of those wire nuts and use something better (assume you're just using them for debugging).
A k5 should have a fusebox with three fuses, a 15A main fuse, a 7A headlight fuse, and a 3A tail light fuse.  This connects to a modular connector under the left side cover.
mystic_1
Offline mrbreeze
  • Not your average
« Reply #14 on: January 10, 2016, 08:27:52 PM »
I just did this last night on my bike. I've got it pretty stripped down but decided I want to do a compression test before I go in. To jump it with the wiring harness disconnected you hook the battery up like normal. Run a jumper from battery positive to the big starter wire on the solenoid. Disconnect the small black wire to the solenoid and touch it on positive. This will turn your starter.
MEMBER # 257
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=s6cusqloca88obap7t7k1jlm14&/topic,60973.0.html
« Reply #15 on: January 11, 2016, 08:01:24 AM »
i dont see the thik vire from zolonid schrev pole ,, konnekted to  starter ...is the starter vired up..
« Last Edit: January 12, 2016, 03:40:12 AM by strynboen »
i hate all this v-w.... vords
Offline T100
« Reply #16 on: January 11, 2016, 12:12:30 PM »
Put a jumper on the solenoid contacts. That will bump it.
Tyler
