Author Topic: $200 budget for front and rear tires  (Read 1725 times)
Offline mycoal
« on: January 10, 2016, 11:32:06 PM »
I'm looking for tires that last a long time and grip really well in the wet. 1978 CB750k. Driving is standard street stuff. Nothing high speed or fancy. I hate riding in the rain but want to have some kind of confidence if I have to do it. Rims have spokes if that matters. What do you recommend?
1978 CB750K with 1977 GL1000 front end
Offline brewsky
Re: $200 budget for front and rear tires
« Reply #1 on: January 11, 2016, 01:06:46 AM »
These are what I use on my '78k........
Dunlop D404  ...100/90-19; 130/90-17
less than your budget shipped.
You will likely get other recommendations as well.
http://www.motorcycletiresmaniac.com/Dunlop-D404-Motorcycle-Tires.html#3920
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #2 on: January 11, 2016, 02:22:46 AM »
You, of course, realize that you are asking for conflicting attributes.  Good grip, especially in the wet, requires a softer rubber compound.  Softer compounds do not last as long.  Durability requires a harder compound.  Harder compounds don't grip as well...then there are dual compound.  Hard in the center for durability, soft on the sides for grip...but its gonna be tough to meet your budget.  Good luck.
Online PeWe
« Reply #3 on: January 11, 2016, 03:15:32 AM »
I have Dunlop Arrowmax Street Smart.
http://www.dunlopmotorcycle.eu/dunlop_euen/mc/tyres/on_road/Arrowmax%20StreetSmart.jsp
front 100/90-19V   rear 120/90-18V
Seems to be better than  my previous Metzeler LaserTec that had very short life on rear.
Offline flatlander
« Reply #4 on: January 11, 2016, 04:23:05 AM »
seanbarney is right.
your budget is not that bad if you shop around but you may end up exceeding it a bit. get the tyres that work best for your kind of riding and the conditions where you ride. at the moment when they slip out out from under you, the price of a pair of tyres will be the least of your worries.
i use bridgestone bt45 myself. it rains quite often here and they do ok, i'm happy with them.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #5 on: January 11, 2016, 05:07:31 AM »
mycoal,
I run Continental RB2 (front) and K112 (rear).  They grip pretty good and wear pretty well.
Charlie
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: January 11, 2016, 05:38:05 AM »
Kenda Challengers work for me. Even with new tubes, rim strips and free shipping you're within the $200 budget:
http://www.motorcycle-superstore.com/6097/i/kenda-k657-challenger-rear-tire
http://www.motorcycle-superstore.com/6096/i/kenda-k657-challenger-front-tire
Haven't had them long enough to determine how many miles they will last, but they are reasonably priced.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: January 11, 2016, 05:59:10 AM »
Not that hard actually, in Superstore:
http://www.motorcycle-superstore.com/6013/i/bridgestone-battlax-bt-45-sport-touring-rear-tire
http://www.motorcycle-superstore.com/6012/i/bridgestone-battlax-bt-45-sport-touring-front-tire
Or you could go Shinko:
http://www.motorcycle-superstore.com/6205/i/shinko-712-rear-tire
I used Shinko 712 myself on Dorothy, took her through tail of the dragon fully loaded and never had a problem.
« Reply #8 on: January 11, 2016, 07:08:45 AM »
My go-to budget tire is the IRC GS-11...vintage tread pattern, made in Japan and available in inch sizes.
http://www.amazon.com/dp/B006B22WN4/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3ZEPRV1QIOFI&coliid=I1XUC92ZRLMTGK
Dont forget to oder tubes and rim strips.
« Reply #9 on: January 11, 2016, 07:33:37 AM »
www.americanmototire.com
4k mi on the shinko 712s that the PO put on my K8.  So far so good.
Offline Restoration Fan
  • My wife will never call me
« Reply #10 on: January 11, 2016, 10:47:45 AM »
Pirelli Sport Demons on my 78K.  I've really enjoyed them.  I only have about 800 miles on Stella since the rebuild but so far the tires aren't even showing signs of wear.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=s3vfgphiqd9936k012a43n3p42&/topic,60973.0.html
« Reply #11 on: January 11, 2016, 11:01:26 AM »
use menzler on road..and heidenau off road/winter
i hate all this v-w.... vords
« Reply #12 on: January 11, 2016, 11:30:52 AM »
I am not sure about tire having to be soft to work well in rain, i thought it had mote to do with getting water out of the way to prevent hydroplaning... That said, Brit brands always seem to work well in rain.they would have no tiresales if that were not true..
Offline Tim2005
« Reply #13 on: January 11, 2016, 01:26:41 PM »
Frank is onto something there, here in the UK we regularly test the all weather performance- I did this morning, again...
I'm not sure about US prices and the $200 target,  but for great wet weather performance and decent wear you ought to consider Avon AM26s.
« Reply #14 on: January 11, 2016, 01:57:34 PM »
I loved the Avon AM26s on my 350F, but with new rim strips/tubes/mounting/balance, you're looking at near $300
« Reply #15 on: January 11, 2016, 02:01:53 PM »
+1.  Def not a budget tire, I have them on my Z1 and love them...
