Author Topic: Parking brake function  (Read 4927 times)
Offline Cougars750F0
« on: January 11, 2016, 02:43:16 PM »
My 750A is hard to push is this normal? Is the parking brake sticking? How does one set and release it? It's worse when the bike is cold. Thanks in advance for any help.
1970 Honda / Yoshimura 810 with ported head, 1968  Honda CB450 5 speed European model, 1973  Triumph Bonneville 750 twin carburetor model, 1975 Honda 750F0 Super Sport, 1977 Honda 750A
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Parking brake function
« Reply #1 on: January 16, 2016, 04:55:34 AM »
The Hondamatic should roll as easy as any bike. It's more than likely that your front brake is dragging as opposed to the rear brake. Put the bike on the center stand and see if the rear wheel is dragging. To use the parking brake, apply the rear pedal while pulling out on the knob on the left side. To release, depress the button and push in the knob and push down on the pedal to release the brake.
.........Paul
Offline Feragos
« Reply #2 on: March 10, 2017, 11:36:08 PM »
Hi, I can't  find the parking brake know, can you please punted out? I just bought a 97 750A so I'm still getting to know it.
Thanks in advance
Offline 05c50
  • 05c50
« Reply #3 on: March 11, 2017, 11:39:51 AM »
The park brake control knob should be mounted under the left side of the fuel tank about 5 inches behind the petcock. The cable goes from there to the peg mount on the right side.
....Paul
Offline Remcod
« Reply #4 on: March 11, 2017, 12:19:53 PM »
But you have to push down the rear brake lever after you pulled the knob to engage the brake. Push the button on the knob and then the lever again to release
Offline Old Scrambler
« Reply #5 on: March 12, 2017, 05:35:31 PM »
That's assuming it works ;)
If the bike has been sitting for a few years, its likely to need cleaning and proper cable lubrication.
The actual purpose of the parking brake is to hold the bike on any slope because you can't just leave it in gear to keep it from rolling.
« Last Edit: March 12, 2017, 05:37:23 PM by Old Scrambler »
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Dave Mac
« Reply #6 on: November 16, 2017, 09:54:41 PM »
Hi,  I know this original post is almost two years old,  but I was wondering what ever became of this situation? I recently acquired a '77 CB750A and after googling the same issue I let me to your post. Far as I can tell, it's my rear wheel that seems very tight,  it will not spin on the center-stand if you try to spin it with your hand. The bike is not in 1st or 2nd gear,  and the park brake is 'off' as far as I can tell.  I don't hear anything rubbing... did you find out why your's is this way?  Thx,  Dave-
Offline 05c50
  • 05c50
« Reply #7 on: November 19, 2017, 03:49:33 PM »
Check your rear brake operation. You could try loosening the rear brake adjuster to see if that frees up the rear wheel. The brake pedal pivot may be rusted and not moving freely, mine was like that and caused the rear brake to drag.
.....Paul
Offline Dave Mac
« Reply #8 on: November 20, 2017, 07:13:54 PM »
ok thx Paul will do.  regards,  Dave-
