Author Topic: Changing one spoke  (Read 965 times)
Offline Garage_guy_chris
Changing one spoke
« on: January 11, 2016, 08:07:24 PM »
Hey guys while I was cleaning the bike I found a loose spoke and tried to snug it up, when i did it snapped. I checked every other spoke and didn't find any other issues so Im gonna need to replace just the one spoke.
What needs to be done to replace just the one spoke?
Offline Flyin900
Re: Changing one spoke
« Reply #1 on: January 11, 2016, 08:16:13 PM »
Remove the tire and replace the rim strip. Replace the spoke and it may be worth checking the rim for runout. I usually have my local shop handle that stuff with dropping the wheels off there.
You may find the rim/spoke nipples are rusted under the rim strip and hence the breakage when you tried to tighten it up.
The guy I use removes the tire and I pick up the rim and do the general clean up of all the rust and shoot each nipple with a release agent and check that each spoke can be adjusted. Drop the rim back off and he trues and remounts the tire with a new rim strip and tube (supplied by me) and balances.
Cash is king and he charges a very reasonable rate for me doing the grunt work.
« Last Edit: January 11, 2016, 08:18:52 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline disco
« Reply #2 on: January 12, 2016, 04:01:49 AM »
Hi Chris,
There are 2 types of spokes ie 'inners' & 'outers'. If your broken spoke is one that feeds in from the inside of hub, then it's easily replaced. If however it feeds from outside the hub, then you'll have a bigger problem. You'll need to remove more spokes in order to be able to turn the new one into position.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
