Author Topic: Odd O-ring size for CB550K1 petcock inner assembly  (Read 1364 times)
Offline tkarahalios
« on: January 15, 2016, 10:22:20 AM »
Hi all,
I am rebuilding my petcock for a 1975 CB550K1. It has the odd petcock without the sediment bowl on it as shown in the image below. I bought a Honda rebuild kit that came with everything I need except it did not come with the o-ring that sits inside the petcock assembly right behind the selector valve switch.
I tried to find the part number online but had no luck. It seems to be listed as part of the assembly and not have a separate number. I tried to measure it with calipers and I think its about 19mm inner diameter, by somewhere around 1.6-2.0mm cross sectional diameter. It's hard to tell because the o-ring has sat in there so long the cross section is not very round anymore.
Does anyone know what the dimensions for this might be? or a part number for it? Just wondering if anyone has gone down this road before. I'm just trying to avoid ordering different sizes to get it right since the only place I know of to order them sells them in bags of 50. (McMaster Carr).
Thanks.
Offline basic
Re: Odd O-ring size for CB550K1 petcock inner assembly
« Reply #1 on: January 15, 2016, 11:13:18 AM »
Check amazon for orings. Search by the as568 size. You can get a chart of sizes here: http://www.marcorubber.com/sizingchart.htm
A quick glance looks like it's close to a -018. Amazon has a set of 5 for 68 cents.
http://www.amazon.com/dp/B000FN0ZDO/ref=biss_dp_t_asn
Good luck and report back.
Offline Gene
  • Chat enuf you too can be a
« Reply #2 on: January 15, 2016, 12:27:56 PM »
I have that same model petcock - another member was trying to rebuild his as well - and we found this out
"Re: Please help me identify this petcock
« Reply #21 on: June 30, 2015, 05:45:27 PM »
 Like I said....rebuild kits are  not available for that part. It was a faulty design and Honda went with something else after that year.
 Your best bet is finding a member with an old leaky one they've replaced and see if they'll sell you the handle.
 Still order the filter part, though."
You can go to that thread - there is at least a replacement in-tank filter available, but you're gonna have to wing it on the o-ring.
http://www.davidsilverspares.com/CB550K-1976-USA/part_70857/
I got lucky and found a replacement on ebay - but it's a one-year model petcock.
I'd be happy to mail you my old one if you think you can use any parts off it.
« Last Edit: January 15, 2016, 12:29:28 PM by Gene »
*1973 CB750K3 (Bow)
Offline tkarahalios
« Reply #3 on: January 15, 2016, 06:42:45 PM »
Thanks guys,
I just ordered the o-ring "Basic" found on Amazon for me. What a deal. I get 5 of them shipped to me to arrive this Monday all for $0.69 and that includes shipping and handling since I have Amazon Prime. Unbelievable.
Gene, thank you for the offer. I have the rebuild kit you mentioned, and I dropped the parts in an ultrasonic bath my friend has. So, if the new o-ring I just ordered doesn't fix things I may reach out to you for your old parts.
Cheers and good night guys.
« Reply #4 on: January 15, 2016, 07:44:34 PM »
Is it a 75 ? I had a too big oring in mine., went smaller it broke....back to big one with screws backed off.
Not sure if original had an o Ring or square section ring..
Honda is known to use a lit of tween sizes on o ring cross sections..
To. Measure. Your flattened one  take the fat and thin measurement..average out the difference. Should close to the real size.
Offline basic
« Reply #5 on: January 16, 2016, 09:44:49 AM »
hope it works.
the size suggestions was just given off your measurements. You may find it's better to go to a 100 series oring to get a little extra cross section. If this is the case, then a -116 is probably in order. It's 2.6 mm diameter vs 1.8 mm in thickness.
http://www.amazon.com/dp/B000FN0X54/
If the cross section thickness of the -018 is good but diameter is a bit off, the next smaller/larger is a full mm difference in diameter, so you may need to go to a metric o-ring.
Offline tkarahalios
« Reply #6 on: January 16, 2016, 12:00:32 PM »
So it is for 1975 CB550. It looks kinda like a square profile but I think it's maybe the result of a 40 year compression set. I ordered the 018 size from Amazon. I'll report back what I find out when it arrives Monday. Again since it costs less than dollar with shipping it's worth trying...
« Reply #7 on: January 16, 2016, 02:06:52 PM »
If it was square, it wont have much roundness to it.
