Author Topic: Brake master rebuild  (Read 1507 times)
Offline beemerbum
« on: January 17, 2016, 03:54:30 PM »
After exhausting my extensive vocabulary of dirty words, I finally got the F'n little snap ring out of the '71 master cylinder. When the piston, spring, etc. were removed, there was what I expected, crystallized brake fluid residue. What is a good liquid to soak the cylinder to clean it out before the new parts go in?
Re: Brake master rebuild
« Reply #1 on: January 17, 2016, 04:06:41 PM »
Brake Kleener or Xylol will do.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: January 17, 2016, 04:40:54 PM »
Get down in there with a brush or something too, crap likes to hide in the corners.
mystic_1
- John Augustus Shedd
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: January 17, 2016, 04:49:04 PM »
mystic_1
+1
I like to use an appropriately sized brass bottle brush for the bore, and then a dental pick for the snap ring groove.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Flyin900
« Reply #4 on: January 17, 2016, 07:29:21 PM »
Make sure you clean the very tiny return hole in the master cylinder body. Very easy to miss if you aren't familiar with the two fluid holes in the master cylinder. If that remains plugged the brakes will either seize on the caliper or drag.
If you have the plastic fluid reservoir it should be removed and the O ring cleaned up. I have found soaking the whole master in very hot water for 15 minutes and then using a rubber strap oil filter device used for removing car oil filters works really well.
The strap is adjustable down to a small size if the strap tool itself is one of the smaller ones. It won't damage the plastic reservoir and will allow you the start to get some purchase on twisting it loose.
I usually hold the master in a vise in a cloth to enable me to get a good twist on the part.
« Last Edit: January 18, 2016, 07:29:23 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline beemerbum
« Reply #5 on: January 18, 2016, 08:30:59 AM »
I'm glad you mentioned the two tiny holes. One of them is now clear and a probe inserted into the hole shows up in the bore, The other little hole next to it appears plugged. When I push on the obstruction from the reservoir, it seems like there is a tiny ball in it that springs back as if it has a spring under it, sort of like a pressure relief device. Am I imagining things? Maybe better whiskey is in order.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: January 18, 2016, 09:56:28 AM »
They're both just plain holes, no check valves, but one of them is tiny in comparison to the other.
Try going in there with a single strand of copper wire pulled from a piece of scrap wire.
mystic_1
Offline robvangulik
  • Honda Fourever
« Reply #7 on: January 18, 2016, 01:37:48 PM »
I recommend Bushmills Black Bush, smooth but still cleans the sinusses.
And no tiny balls in the master cylinder, I use sewing needles to push those holes open, they are thin enough, available in many, also very small, sizes, and more sturdy than copper wire.
« Reply #8 on: January 18, 2016, 01:57:27 PM »
Very, very tiny...
TAMTF...
Wilbur
Projects:
Offline krusty
« Reply #9 on: January 18, 2016, 02:27:46 PM »
Steel #1 or top E guitar string is perfect for the job of clearing that little hole. Copper wire is too soft.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #10 on: January 18, 2016, 04:16:41 PM »
OK, all of the above as far as cleaning out the holes at the bottom of the MC is great. The dried brake fluid simply quickly dissolves in denatured alcohol. Soaking is not required.
