Author Topic: 550 cam gear  (Read 1111 times)
Offline yellowjacket
550 cam gear
« on: January 21, 2016, 07:57:39 AM »
Is there a front and back to the cam gear? It looks like it could go either way.  Also, is there a trick to getting the chain onto the gear?
Thanks
Offline flatlander
Re: 550 cam gear
« Reply #1 on: January 21, 2016, 08:14:38 AM »
it's symmetrical.
to mount it, put the cam in place with the chain resting where the sprocket would go, and the sprocket loosely on the cam, next to it. like in the picture.
then lift the chain onto the sprocket. then the sprocket onto the flange where it belongs.
Re: 550 cam gear
« Reply #2 on: January 21, 2016, 11:48:22 AM »
Thanks for the reply.  Went home at lunch cam gear is on.
Offline flatlander
Re: 550 cam gear
« Reply #3 on: January 21, 2016, 12:56:18 PM »
sounds like a successful lunch break :)
Offline DaveBarbier
Re: 550 cam gear
« Reply #4 on: January 21, 2016, 03:07:18 PM »
What did you eat?
Offline flatlander
Re: 550 cam gear
« Reply #5 on: January 21, 2016, 11:05:09 PM »
gears and chains, apparently ;)
