Author Topic: K5 main jet questions  (Read 1176 times)
LouisTheCat
« on: January 22, 2016, 06:52:18 PM »
So I've got a K5 with a modified engine... Problem is that I only know that it was a bore job with new pistons and rings but I don't know the exact specifications.  I'm looking to put on a 4-4 exhaust and should I just use 105's since that is the stock jet size? Carbs were rebuilt with 110's for mains (with a 4-2 exhaust and that was running rich when I put the bike away for the winter and started working on it. Carbs are 657B
Re: K5 main jet questions
« Reply #1 on: January 22, 2016, 07:05:59 PM »
What air filter?
LouisTheCat
« Reply #2 on: January 23, 2016, 06:14:22 AM »
aftermarket filter. I plan on replacing it with a genuine one.
Offline cb650PK
« Reply #3 on: January 23, 2016, 06:33:17 AM »
My stock exhaust equipped K5 run better with 110 main then the 105. It had Andrews coils and MaxiDwell points and you could probably weld with the spark it had, so fouled spark plugs were not even possibility.
S CB750 na vecne casy a nikdy jinak.
« Reply #4 on: January 23, 2016, 08:02:28 AM »
assuming that filter is in the stock airbox...I would start tuning with the 110's.  My guess is it will certainly be rideable with the 110's.  Be SURE your fuel level in the bowl is correct before you start tuning.  I have ended up with anything from 105 to 120 on similar combinations
LouisTheCat
« Reply #5 on: January 23, 2016, 07:58:54 PM »
I'll try that. thanks for the input
