Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 187485 times)
Offline BLAC
  • An espresso is a
Re: 1974 Honda CB550 Build. "BlackSOHC"
« Reply #175 on: April 15, 2016, 08:14:43 PM »
Thanks, I'm starting to understand it more.
I have installed 5ohm Dyna coils, Dyna wires, 5kohm resistor caps with resistor plugs.
I also plan to order the Hondaman ignition.
(Side question, I thought I was told to run resistor caps and plugs together with his ignition, does that sound right?)
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline BLAC
  • An espresso is a
« Reply #176 on: April 18, 2016, 12:42:07 AM »
This has been a weekend of progress.  The frame is completely stripped, hubs have been cut out and polished, forks have been disassembled and polished (waiting on new tubes to reassemble with), handlebar mounts on the triple have been cut off, front and rear hubs have been disassembled and bearings removed..
I'm sure I'm forgetting stuff, but I have put about 10 hours into it the past couple days, its pretty amazing the number of pieces that make up these bikes  :P
This is just sanded, no buffing wheel yet  ;D
Offline calj737
  • I refuse...
« Reply #177 on: April 18, 2016, 03:59:32 AM »
Good to see people get to work on their bikes. Remember, when you reassemble the forks, the crush washer that is installed on the lower, up into the leg that secures the rod needs to be there. If your stock washer is not destroyed, re-anneal it and re-use it. Else, replace it. A little grey AntiSieze on the threads of the bolt too before installing makes it much better next time to remove. Same for the small drain screw on the side.
Offline BLAC
  • An espresso is a
« Reply #178 on: April 18, 2016, 11:50:19 AM »
Yep, I actually ordered all new hardware from Race-tech along with the springs/oil/gold valve emulators.
In other news, I have developed a new hatred of polishing metal.... anyone have pointers to speed it up or is it just best done by hand with 320, 400, 600, 800, 1000 grit sand paper.
Im running low on elbow grease..
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #179 on: April 18, 2016, 11:59:48 AM »
Sure... farm it out. Or, do like I do and don't polish at all. I don't mind having a 10-footer, but I guess if I ever disassemble for a restoration... it will be prudent to polish.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline calj737
  • I refuse...
« Reply #180 on: April 18, 2016, 12:59:39 PM »
Degrease it. Bake it. Wipe the grease off again. Glass bead it. Wetland it with 1500, then polish. PITA to make look wonderful. Long live Powder Coat!!!
Offline Camrector
« Reply #181 on: April 18, 2016, 01:18:24 PM »
I've had great results with a hand held orbital sander, and time.
Offline BLAC
  • An espresso is a
« Reply #182 on: April 18, 2016, 01:21:12 PM »
Sounds good!  I will keep at it!
I have the bike pretty much pulled completely apart.  Aside from the engine, I'm not sure if there are two parts bolted together anymore  :o
The amount of time and money I'm going to have into this thing, might as well suck it up and keep sanding  :'(
OH does anyone have a suggestion to where I can get my frame sandblasted (if that is the right blasting that is preferred) in Los Angeles?
Offline MickB
« Reply #183 on: April 18, 2016, 02:34:27 PM »
Ser, unfortunately elbow grease is the way, the sandpapered you mentioned will give great results, I also use a Dremel with a little polishing pad and it works fantastic.
Offline GV1390
  • Express Gratitude.
« Reply #184 on: April 19, 2016, 05:20:58 AM »
Remember when you told me you just wanted to add a couple bolt-ons and keep a low budget? That didn't last long! haha.
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline BLAC
  • An espresso is a
« Reply #185 on: April 19, 2016, 11:36:03 AM »
haha yep, I probably have 4k into it at this point  :o
now I'm just waiting on my seat cowl and rear loop to show up  :P
Offline rhodeleon
« Reply #186 on: May 03, 2016, 09:31:52 AM »
I ran into a similar issue with my '76 550. Rebuilt the carbs, put them back on, opened the fuel valve and out comes gas from the T junction between 1 and 2. Disassembled them again to check the float chambers, and it looked like gas was getting into all of them. Adjusted the floats as specified and hit them all with carb dip and tried again, same thing. Bike starts and sounds pretty good, but idk why the hell gas is leaking out. Did you end up finding the root cause/have any guidance on where to go next?
Offline Camrector
« Reply #187 on: May 17, 2016, 12:39:22 PM »
I'll pm you about my cowl.
Offline BLAC
  • An espresso is a
« Reply #188 on: May 17, 2016, 04:41:41 PM »
Cool, got things worked out with my cowl.  Should be here in 2 weeks, and I have also made the decision to chop up the subframe and make a new clean one.
She will be pretty one day!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #189 on: May 18, 2016, 03:44:06 PM »
Traffic.. how did you know I lived in LA  :P
I was thinking about finding a stock harness. but I want to minimize and simplify everything on this bike (no horn, no starter, etc etc.  Just the bare minimum to let the bike run)
I wouldn't ride in the city without a horn. Too many stupid people, drivers and pedestrians.
« Last Edit: May 18, 2016, 03:48:07 PM by Bankerdanny »
« Reply #190 on: May 18, 2016, 03:49:00 PM »
Hah! I was thinking of installing a Stebel Nautilus horn (139dB) on my next build, but it is a heavy sucker.  http://www.stebel.it/stebel/products.asp?IDserie=6&uso=1&tipologia=auto
Does anyone know of a comparably loud yet lighter alternative?
« Reply #191 on: May 18, 2016, 04:05:40 PM »
The Nautilus is a nice one but it is bulkier than stock. It can fit in the stock location but I decided to make a thicker mount bracket to handle the weight and haven't finished it.
It will get attention. I got hooked on air horns running a Hella unit in my '66 Volvo 122S. The higher pitch got attention.
No one can claim they didn't hear you.
I guess you could go crazy and mount a train horn on the front  above the fender if you wanted a horn to make people jump even higher.
Offline BLAC
  • An espresso is a
« Reply #192 on: May 18, 2016, 04:19:53 PM »
I am thinking about hiding it up under the fuel tank, but then again I dont plan on having any buttons on the handlebars.. well see.
Offline calj737
  • I refuse...
« Reply #193 on: May 18, 2016, 05:20:08 PM »
If no buttons in the handlebars, then where will you position the KILL switch?
I never use a horn, in a car or on a bike. It's my opinion that honking a horn on a bike tends to cause the would-be car/driver to freeze and stop dead in their tracks, right in my way. I'd prefer to get off the throttle, steer behind their path, and then ride away. I've seen too many bike accidents where the bike T-bones a car that has pulled out and the bike has blown the horn, and whammo!
Just my opinion. Being in the "right" legally doesn't keep you alive.
« Reply #194 on: May 19, 2016, 07:43:48 AM »
Sometimes I will use a horn if it looks like the driver is going to make the turn ahead of me. That way if I'm wrong it might just prevent them from making the move, whereas if I'm right they will have done the deed a little faster I hope or know they are doing it.  People can't judge the speed of motorcycles I think...they often think they are slower than they actually are, not perceiving the speed as easily. Some drivers cut it very close even with cars.
Daughter hit a car that darted in front of her while she was braking to stop for a line of cars and the guy was totally in front of her and she was cited for hitting him.  Not cool but, it is the law.  Jerks out there everywhere.
David
Offline BLAC
  • An espresso is a
« Reply #195 on: May 19, 2016, 11:42:10 AM »
Im thinking somewhere under the seat pan.  Not set on anything yet.
I agree with you on the horn, and for all of the other uses like "merging into my lane without seeing me", that's what I use the 4-1 horn for =)
« Reply #196 on: May 19, 2016, 01:36:26 PM »
On a bike, the only time I use the horn is when people don't see me and are merging into my lane, but they never hear it anyway, so I just have to move to save my bacon.  It would be nice to have a "wake up, a-hole!" horn for that purpose.
Offline BLAC
  • An espresso is a
« Reply #197 on: May 19, 2016, 02:08:47 PM »
I think the best thing would just be a loudspeaker paired up to an in-helmet microphone.  That way you could tailor each expletive to the situation at hand  :P
Offline joeyvans
  • Definitely not a
« Reply #198 on: May 19, 2016, 03:21:59 PM »
And don't forget your riding gloves with armored knuckles. Great for removing car mirrors without the aid of hand tools.
1976 CB550 K2
Offline BLAC
  • An espresso is a
« Reply #199 on: May 19, 2016, 09:26:04 PM »
Honest to god, the first week I had my old R6 here in LA (moved from Oregon) a guy signaled and started coming over into my lane (two lane road).  I was almost right at his window so I had no idea how he didn't see me, as I was honking he turned and made eye contact with me, and continued to squeeze me toward the center median!  So I sent him to the Ford dealership to buy a new side mirror...
