Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 187603 times)
0 Members and 10 Guests are viewing this topic.
Offline BLAC
  • An espresso is a
Re: 1974 Honda CB550 Build. "BlacSOHC"
« Reply #250 on: June 13, 2016, 03:23:23 PM »
I like it with the stock tank.  I assume blacSOHC has already worked out his suspension mount points, geometry and adequate support for the new subframe.
Yes, I took measurements from the stem to the stock mounting points for the rear springs and plan on getting it pretty much exactly the same.  I bought the mounting kit from Cognito so it should be a clean and straightforward weld in solve.
On the support bars, I am going back and forth on whether I want to recreate them in the factory spot (creating the large 'triangle' area) or mount them higher up on the bar behind the motor creating a shallower/sleeker triangle.  If that makes any sense...
I will mock up some photoshops soon  8)
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline BLAC
  • An espresso is a
« Reply #251 on: June 13, 2016, 03:24:02 PM »
Are you planning on using that tank?
Yes, I am going to try to get a little creative with it i think.. there are two dents on it, one on each side in almost the same place, so I am still trying to figure out a game plan that addresses that.
One idea I have been kicking around is cutting out the whole 'black part' of each side and swapping them to the other side.  It would take some massaging and fab work, but I think it might be a cool (and unique?) look instead of just having the knee dents only at the back of the tank.
Why do you ask? were you wanting to take it off my hands or see something wrong with it that I should address haha
Offline BLAC
  • An espresso is a
« Reply #252 on: June 13, 2016, 03:34:20 PM »
Here is what I am debating for support bars.. I think it will be one of these 4 spots.
any insights or thoughts I should be considering?
Offline calj737
  • I refuse...
« Reply #253 on: June 13, 2016, 03:47:57 PM »
#4 is easiest as its stock.
#1-3 are fine too, but you need to cap the stock frame hoop where you cut the subframe loose (obviously).
Just use a decent tube, not cheap tubing. I'd suggest DOM 1/8" wall. Stock tubing is less than 1/16" wall thickness.
Offline BLAC
  • An espresso is a
« Reply #254 on: June 13, 2016, 04:03:07 PM »
I have chromoly '4130' from Cliff.  It is really heavy duty stuff.  WAY stronger than the stock paper mache  tubing honda used.
« Reply #255 on: June 13, 2016, 04:14:05 PM »
Why do you ask? were you wanting to take it off my hands...
Yes!  Thought it looked too good to chop up and may look better on my bike!
Offline BLAC
  • An espresso is a
« Reply #256 on: June 13, 2016, 04:37:30 PM »
Haha gotcha!  The problem with my bike is that everything is ALMOST nice.  It's right on the point where it makes you nervous when you get the saw out, but unsatisfied in its current state..
« Reply #257 on: June 13, 2016, 05:09:15 PM »
Question: why cut off the subframe if you are going to replace it with support in the stock location (aka #4)?  Was the stock subframe tube damaged?
From a aesthetic sense, I like the cleaner look of 1 and 2, but for something like this, function needs to dictate form.  You will be putting a fair load on that subframe.  1 and 2 may place too much stress on the new tubes, even if they are chromoly.
Offline BLAC
  • An espresso is a
« Reply #258 on: June 13, 2016, 05:37:51 PM »
Good Question.   I chose to replace it because I wanted to have full control of the structure/aesthetics of the frame.  The stock frame is not made of straight bars and contour in ways that don't lend themselves visually to the rear cowl and the suspension mounts are incorporated into the stamped metal.  It will be be a lot nicer once I purpose build everything.
« Reply #259 on: June 13, 2016, 09:26:23 PM »
Very true. The subframe is slightly concave as to the frame rails. Are you fabricating your own shock mounts or using pre-fab mounts?
Offline Camrector
« Reply #260 on: June 13, 2016, 10:31:12 PM »
"Yes, I took measurements from the stem to the stock mounting points for the rear springs and plan on getting it pretty much exactly the same.  I bought the mounting kit from Cognito so it should be a clean and straightforward weld in solve. "
Looks like prefab  CB.
I'd vote for #1 based on looks.
Offline BLAC
  • An espresso is a
« Reply #261 on: June 14, 2016, 12:36:13 AM »
Yep, I bought the mounting hardware and plates from Devin, I just hope the angle that the plates were cut at provide me with enough tilt to line up and accommodate something like #1
I agree that #1 looks the best.  I'm going to get the length of the loop set up and welded on then I will try a few more mocks for the support bars.
I also ordered a tap set today so I will be able to get working on my Motogadget ideas :)
« Last Edit: June 14, 2016, 12:39:01 AM by blacSOHC »
Offline BLAC
  • An espresso is a
« Reply #262 on: June 15, 2016, 11:25:14 PM »
1.5
My tap set came in the mail, and the thread pitch is a 1.0... The only size not included in the 40 piece set I bought  ::) >:( :'(
Offline calj737
  • I refuse...
« Reply #263 on: June 16, 2016, 04:58:55 AM »
I just re-read the original question, and noticed you said buttons. Sorry, when I responded I was thinking pins as we had bantered about the units Trad sold me.  :'( Give me your address via PM and I'll send a 12mmx1.0 tap off to you as atonement.
Online RAFster122s
« Reply #264 on: June 16, 2016, 06:22:36 AM »
Do the M button take a 12x1.0 pitch thread instead of 12x1.5 thread?  Just to clarify...I am a little confused, or don't follow.
A trip to a bolt and fastener store with the M button could answer the question of coarse. Are you threading the M button into a plate/triple tree or just putting it through a hole where the backside is accessible for a nut?
Online RAFster122s
« Reply #265 on: June 16, 2016, 08:33:07 AM »
Would you be able to achieve a strong enough structure if you instead of bracing it as shown go to a box section coming back from the original frame of sufficient thickness and cross section to eliminate the need for the additional bracing and gusset it as well as create a cross bracing in a geodesic design to make it rigid as well?  Or, are you going to have to have a triangular brace tube as you are showing?
Just wondering if you could think further out of the box.  Naturally, the end of the loop would probably need to be a tube or similar as bending into a curved hoop in box section isn't easy or practical. It can be done, just not ideal. You could even take the hoop and face it with a flat section if you wanted to match the profile of the hoop with a section of U channel with it cut and welded so the inside is a half round and outside face is a box section.  That would further strengthen that part of the hoop, but merely for asthetics.
If you have access to fabricating equipment that can bend thick walled tubing, then go for it...
Just throwing out a different idea.
Online RAFster122s
« Reply #266 on: June 16, 2016, 08:42:26 AM »
What are you doing for rear shock mounts and rear swingarm since you cut off the rear frame?
Offline BLAC
  • An espresso is a
« Reply #267 on: June 16, 2016, 09:09:15 AM »
That is very nice but not necessary.  I thought the kit came with 1.0 1.5 and 1.75.  It was advertised poorly and I thought I was covering my basses.  I'm just going to head to a Home Depot or something and buy a single one.  Thanks for the offer though!  8)
Offline BLAC
  • An espresso is a
« Reply #268 on: June 16, 2016, 09:10:48 AM »
Yes the buttons are m12 1.0    Yes I am threading them into a plate, not accessible from the back
Offline BLAC
  • An espresso is a
« Reply #269 on: June 16, 2016, 09:12:49 AM »
I bought a kit from cognito with some plate and mounting pegs.  It is the one used on their Fox cb350
Offline calj737
  • I refuse...
« Reply #270 on: June 16, 2016, 04:17:19 PM »
Just for clarification: m-buttons are not what you're using. The m-button is a wiring concentrator. The m-switch is their momentary button product. But they come in housings. Are you buying generic momentary switches or removing the MotoGadget momentary switched from their housings and installing a plate?
Offline BLAC
  • An espresso is a
« Reply #271 on: June 16, 2016, 05:31:00 PM »
Correct, I didnt mean to confuse it with the m-button, which does not have threads.
I am using and referring to the Motogadget 'Push Button'
here is a little sneak peek...
Offline BLAC
  • An espresso is a
« Reply #272 on: June 20, 2016, 01:58:56 PM »
I had a productive weekend with this old girl.  The subframe is mocked and tacked up!
Offline calj737
  • I refuse...
« Reply #273 on: June 20, 2016, 02:37:06 PM »
I like the look. Be mindful with the shock at that angle you reduce clearance to the rear wheel under full compression. Hate to see you run out of room for a fender, tire or tail light.
Offline BLAC
  • An espresso is a
« Reply #274 on: June 20, 2016, 02:39:59 PM »
Yep, that is my only concern as well.  I am going to get the bike all mocked up and put back together to see how clearance looks.  There wont be anything under the rear loop (tail light is integrated into the bar), so unless the tire hits the frame I should be alright... If not I will sell these springs and get ones that are an inch longer.
