Author Topic: 1974 CB550. Racetech Monoshock. JMR Head. Built Engine. "BLAC"  (Read 188858 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: 1974 Honda CB550. Monoshock. "BLAC"
« Reply #400 on: January 14, 2017, 11:50:35 AM »
If you're referring to this, that is definitely not kosher.
I have a motorcycle problem.
« Reply #401 on: January 14, 2017, 11:52:28 AM »
Ouch!  :o
« Reply #402 on: January 14, 2017, 11:54:14 AM »
How was it shifting ? Looks like part of the shift fork maybe gone,not sure how that would happen ?
« Reply #403 on: January 14, 2017, 01:39:21 PM »
Often those fork ends are rough or at least not finished. That one looks rougher than normal (previous contact?) but may have absolutely no negative effect as long as the sliding surfaces are untouched.
Offline BLAC
  • An espresso is a
« Reply #404 on: January 15, 2017, 06:27:33 PM »
I have only ever ridden the bike once, and I don't recall any issues shifting... :-\
I will snap a few more close ups when I am back at my shop.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline BLAC
  • An espresso is a
« Reply #405 on: January 16, 2017, 03:11:31 AM »
Going through old pics and I found a photo of me taken the first time I sat on a motorcycle, and it was a Honda  ;)
« Reply #406 on: January 16, 2017, 09:11:43 AM »
Start 'em off young!  VFR!
« Reply #407 on: January 16, 2017, 02:06:58 PM »
Jeez I thought I was old when that bike came out...
Now I really feel old..sniff...sniff...
« Reply #408 on: January 16, 2017, 02:15:50 PM »
dohhh!...that makes me sad and happy at the same time.  It was an awesome bike before it munched a valve and a piston last summer.  I miss it.DSCN0731 by Sean Barney, on Flickr
Offline BLAC
  • An espresso is a
« Reply #409 on: January 16, 2017, 02:55:08 PM »
wow that's the one! Sorry for your loss  :'(
Offline BLAC
  • An espresso is a
« Reply #410 on: January 16, 2017, 05:13:43 PM »
well you are a "really old timer"   :P
Offline BLAC
  • An espresso is a
« Reply #411 on: January 17, 2017, 12:54:20 PM »
Back to the bike:
Is this plate substantial enough for me to use (with tabs on the underside) as the anchor point under the front of the seat for my monoshock?
Offline BLAC
  • An espresso is a
« Reply #412 on: January 17, 2017, 01:34:34 PM »
Thats what I thought, but I have reoccurring nightmares of riding down the 405 when one of the monoshock mounts lets go..
t'would ruin ones day.
« Reply #413 on: January 17, 2017, 03:27:01 PM »
If it spans the width of the seat rails, i think it could use a doubler..anotr plate or maybe some 1 or 1 1/4  channel across the top.
« Last Edit: January 17, 2017, 06:08:55 PM by 754 »
Offline BLAC
  • An espresso is a
« Reply #414 on: January 17, 2017, 03:57:49 PM »
It is the same shape and size as the tank mounting plate that attaches to the rubber mount, the half moon plate.
I am thinking about boxing it off to add strength as well
Better pics to come...
Offline NobleHops
« Reply #415 on: January 17, 2017, 04:42:22 PM »
Bryan, a TON of force is fed into the shock mounts, especially at the end of a lever in a monoshock position. Err on the side of beefy.
Offline 540nova
« Reply #416 on: January 17, 2017, 05:35:10 PM »
I would add gussets to it.
Offline Restoration Fan
  • My wife will never call me
« Reply #417 on: January 17, 2017, 05:39:15 PM »
I would double the thickness of the metal, weld it to the frame and then weld 2 small gussets on each side.
Considering that monoshock will be sitting beneath your seat, the last thing in the world you want is for the metal to break and the shock to get inserted some place in your rectum...right before you wreck and go down.
« Reply #418 on: January 17, 2017, 06:10:21 PM »
Fiixed my last post.. The small channel atop what you have may do the trick..
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #419 on: January 17, 2017, 06:19:46 PM »
        Whoa, I kinda got a tad behind on this, and looks like progress is still going pretty well. You do some mighty fine work and put slot of thought into a build and it shows. Gotta love the tips and suggestions, from folks here, as it has been said, lots of Valuable info on this forum, from lots of folks who don't mind offering it.  ;)
Member # 1969
« Reply #420 on: January 17, 2017, 07:28:38 PM »
I was thinking late is horizontal , which way is it going?
Offline BLAC
  • An espresso is a
« Reply #421 on: January 18, 2017, 12:24:51 AM »
Yep it will be horizontal with the two brackets under it to hold the spring. (this is the cardboard template)
« Last Edit: January 18, 2017, 12:32:34 AM by BLAC »
Offline BLAC
  • An espresso is a
« Reply #422 on: January 19, 2017, 10:52:18 PM »
Lets crack this thing open!
Rockers look pretty good!
Head action in the shop
Thoughts on this cam chain tensioner?
I found something harder than diamonds.. this old gasket..   >:(
Lets see whats in here..
Offline BLAC
  • An espresso is a
« Reply #423 on: January 19, 2017, 10:56:55 PM »
Allow me to be the 1,294th person to say it.... Nils is the man and vapor blasting is amazing...
Are you kidding me, this is amazing...
This might be the straw that broke the camels wallet.. I might have to split my case and send it off to get beautified
Offline bill440cars
« Reply #424 on: January 20, 2017, 05:09:19 AM »
            Wow, That DOES do quite the job, on those parts! I am impressed!  8)
Member # 1969
